Hello BITOGers,
Just wanted to pass along my experience. I bought it brand new but I never bothered to clean the throttle valve/throttle body. The car now has about 88,500 miles on it. So, while I was waiting for the oil to drain out of the pan this past weekend (takes a while with an 8+ quart sump and a Fumoto drain valve), I found the throttle body spray I purchased a while back, took the air inlet tube off and went to work.
Found a lot of what I would call black varnish on the edges of the throttle valve and the surrounding throttle body that came off with the aid of the spray and an old cotton t-shirt. I cleaned as deep I could get my fingers into the throttle body and then put it back together.
End result? Definitely is idling smoother than before. Car always seemed to have a bit of "chop" to it at idle but I'm definitely happy with the results.
YMMV
Ed B.
YMMV
Ed B.
