Originally Posted By: The_Eric
You could get away with leaning the oil mix on some of the old 2 strokes that were originally made to run on SAE 30 engine oil, but on any modern or semi modern engine, I'd stick with their recommended ratio- or at least really close.
This is backwards. Old 30wt two strokes had bushed conrods rather than needle bearings, and bare aluminum cylinders rather than nickle plated. They absolutely needed 32 or even 16:1 (oil rich). a modern 2 stroke with needle/ball bearings and chrome cylinder will run up to 50:1 (oil lean). I would mix at 40:1 personally.
Oil rich and A/F are two different things. I don't think it makes as much difference as people think.
