Originally Posted By: yucca
Just did the first oil change on the 2014 ram 1500 5.7. The oil filter is much smaller than the one on the 2010. The truck has electronic steering and the oil filter sits on top of that. When you remove the filter it leaks all over it.
Is there any tool on the market to drain down the filter prior to removal?
I'd seriously consider a remote oil filter kit for that situation. You could use a bigger filter that way, too. Its disappointing to see Ram do something like that on a new truck- my 2008 4.7 has an easy to get at filter, AND it has a nifty little built-in chute that directs the filter drippage out over the crossmember so it can fall straight in the catch pan. My SRT has nothing at all under the filter, so other than getting a hand soaked with oil, its very easy and clean as well.
