The window regulator in the driver's side door of my '02 Mazda Protege5 broke. I wasn't expecting to find a aftermarket replacement so I was surprised to find a Dorman replacement for $60. I was expecting an OEM style copy or reboxed OEM from my experience with Beck Arnley parts. Opening the box I found the same function but different mechanical design, some of which seems better than OEM.
This plastic cable guide broke which caused the cable assembly to malfunction, breaking other parts
Dorman on left, OEM Mazda on right
The yellow cable guide on the bottom of the track is a mirror image of the broken part that was on the top. Notice the Dorman cable guides are much more robust and the top guide is attached with a rivet. The motor/cable winding/mounting assemblies are completely different. The replacement fit perfectly.
30 mins disassembly, 20 mins reassembly, Vehicle returned to service
