The manual for my Kawasaki FS691V 23hp engine on my mower doesn't mention synthetic oil, but shows a table with recommended fixed viscosity vs ambient temperature and an API classification of SF,SG,SH,SJ or SL. My area which is >95 deg during summer months calls for an SAE 40. This manual comes across as something out of the 1950s. Other small engine products - ie,Stihl and Polaris not only recommend synthetics, but extend the warranty if they are used. Fixed viscosity oils are not readily available in my area, but I did find a 15W-40 Royal Purple synthetic. The manual does mention that multi-viscosities could result in a higher oil consumption. Strangely, the manufacturer of the mower (Gravely) recommends the first oil change at 25 hours of use while Kawasaki recommends the change after only 8 hours. This may all be just so much conjecture and of little importance, but I plan to use the 15w-40 synthetic after about 15 hous of use. Does anyone have any thoughts or experience with these or similar engines and oil types and use ?
