Moisture inside double pane glass doors.
by Cujet - 04/07/20 09:51 AM
When did mechanics start using rubber gloves?
by atikovi - 04/07/20 09:33 AM
Gearless ratchet
by Farnsworth - 04/07/20 09:22 AM
Troy bilt Zero turn hydrostat fluid?
by racin4ds - 04/07/20 09:20 AM
Bad experience with Monroe strut assembly
by sasilverbullet - 04/07/20 09:16 AM
Hitachi CG22EASSLP
by passgas55 - 04/07/20 09:03 AM
Update: Oil turns dark quickly
by NavyVet88 - 04/07/20 08:48 AM
Do you eat cold pizza or warm it up?
by ZZman - 04/07/20 08:43 AM
This is the turning point...
by Navi - 04/07/20 07:55 AM
accidental fake fraud
by joaks - 04/07/20 07:10 AM
Anyone here try or use Brickell men's shampoo?
by aquariuscsm - 04/07/20 06:49 AM
Adding A Quart for Mustang GT
by ddhmax1973 - 04/07/20 06:29 AM
Victory 106 C.I. filter replaced. . .
by Robster - 04/07/20 06:09 AM
Monaco GP 1992 Senna/Mansell Battle
by IMSA_Racing_Fan - 04/07/20 03:03 AM
RV's for MD's
by 02SE - 04/07/20 01:42 AM
Crawfish, It's A Louisiana Thang!
by BlueOvalFitter - 04/07/20 01:01 AM
M&P .40 Magazines $12.99
by BlueOvalFitter - 04/06/20 11:30 PM
Lots of Big Sur pics, only one of the car :-)
by SLO_Town - 04/06/20 09:24 PM
'16 Pilot Inline ATF filter
by parshisa - 04/06/20 08:55 PM
bigboychunky, maleesha2000, baker269, BludRacing, Cacciatore
71119 Registered Users
105 registered members (Alaskanmont, 64bawagon, 77GrandPrix, 1978elcamino, 007, 4WD, 7 invisible), 2,595 guests, and 14 spiders.
Topics303,715
Posts5,240,519
Members71,119
Head's spinning from what oil for 1970 chevy LT-1 #3365898 05/08/14 07:00 PM
T
Traction Offline OP
T
I have a new 1970 Chevy LT-1 solid lifter 350 that I've had since 1989. Currently has 200 miles on it. Ran Northland Superline 7 15w-40 diesel oil so far. Decided after reading endless posts here and on the C3 Corvette forum, that I need to change soon. So many opinions, it is so hard to make a choice. After reading the Mobil 1 info, that recommended 15w-50 for this engine with a SN rating and proper zinc levels. I decided that is heavier that I would like, so I am leaning toward their 0w-40 Euro spec oil that is SN rated with zinc. Good choice for a very rare low mi. engine? Also has to be a "over the counter oil" that I can get anywhere.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Head's spinning from what oil for 1970 chevy LT-1 [Re: Traction] #3365910 05/08/14 07:06 PM
E
eljefino Offline
E
How built is this? Eg what are the valve spring pressures like?
Re: Head's spinning from what oil for 1970 chevy LT-1 [Re: eljefino] #3365916 05/08/14 07:13 PM
T
Traction Offline OP
T
All stock, engine Chevy sold as a crate engine in the mid 70's. 11 to 1 forged, steel crank, turbo angle plug heads. Awesome engine, runs perfect. Would eventually like to go to a hydraulic roller cam, and E85 fuel, but it runs so good now, I hate to mess with it. It still had assembly lube on the valve train when I bought it for $1000.
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Head's spinning from what oil for 1970 chevy LT-1 [Re: Traction] #3365927 05/08/14 07:22 PM
T
Traction Offline OP
T
The engine is actually in this 81 Camaro in Popular hotrodding. Muncie 4 speed, with a quick change rear, running a 4.47 to 1 gear.
http://www.popularhotrodding.com/features/1405_hometown_hot_rodding/
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Head's spinning from what oil for 1970 chevy LT-1 [Re: Traction] #3365966 05/08/14 08:00 PM
M
Merkava_4 Offline
M
I'd run Chevron 20W-50 (for the solid lifters) with a bottle of Justice Brothers ZDDP treatment.
http://www.automedia2000.com/justicebrothers/JB0906.jpg
Re: Head's spinning from what oil for 1970 chevy LT-1 [Re: Traction] #3365973 05/08/14 08:06 PM
F
fdcg27 Offline
F
An API SN 10W-40 can have higher zinc levels than the same API spec would allow in a 5W-30.
QS Defy 10W-40 might be a good choice.
18 Accord Hybrid 20K HGMO 0W-20
17 Forester 36K VME 0W-20
12 Accord LX 115K SSO 0W-20
09 Forester 119K M1HM 5W-30
96 Accord LX 104K T5 10W-30
95 318i
Re: Head's spinning from what oil for 1970 chevy LT-1 [Re: Traction] #3366017 05/08/14 08:44 PM
I
il_signore97 Offline
I
M1 0W40 would also be an excellent choice. It's a high quality oil that protects many very expensive engines straight from the factory. Should be great for yours.
il_signore97
'09 Mercedes-Benz C300 Sport Calcite White 6-spd M/T
Re: Head's spinning from what oil for 1970 chevy LT-1 [Re: il_signore97] #3366045 05/08/14 09:11 PM
L
Lurgi Offline
L
Joe Mondello, a well respected man in pushrod circles recommended a product called "Cam Shield." You can add it to whatever modern oil you choose in order to pump up the ZDDP to levels that your LT-1 was intended to run on. Mondello said he was having issues with flat tappet cams in the new engines he was building that STOPPED when he began using Cam Shield. And he didn't sell Cam Shield and apparently didn't receive anything from this small company for the recommendation. I have a bottle in the garage. I've used it in a few things but can't really give a meaningful critique. Search for Mondello and Cam Shield and I'm sure you'll find an article where he recommends it. Joe Mondello was one of the great American hot rod engine masters. A master of engines like your LT-1.
Re: Head's spinning from what oil for 1970 chevy LT-1 [Re: Merkava_4] #3366051 05/08/14 09:15 PM
A
aquariuscsm Offline
A
^^This. A 20W50 of your fave brand.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: Head's spinning from what oil for 1970 chevy LT-1 [Re: aquariuscsm] #3366191 05/09/14 12:06 AM
L
Lurgi Offline
L
My old man had one of those LT-1 crate engines. He put it in a '68 Camaro with a close ratio 4-speed and 4.10 12 bolt. That was 1977. I was a kid of 5 or 6. That car took my breath away. I refused to ride in it with him.
Re: Head's spinning from what oil for 1970 chevy LT-1 [Re: Traction] #3366279 05/09/14 07:10 AM
Z
Zaedock Offline
Z
20W50?!?!? That's asinine. All you're going to do is waste power. It's time to drop the old school thinking with today's lubricants.
The 350 in my drag car is based off of your same engine. I have run every oil under the sun in mine (solid lifter, shifting at 6000-6500 RPM), I settled on Mobil 1 5W30 years ago. The last time I changed camshafts for a new profile, the old cam had NO MEASURABLE wear. Break it in correctly with a QUALITY camshaft and you'll be fine.
The M1 5W30 worked great for years, but if I were to change my oil in my Malibu right now, I would use the best oil (IMO) in the XOM lineup, which is 0W40.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Head's spinning from what oil for 1970 chevy LT-1 [Re: Traction] #3366686 05/09/14 01:18 PM
P
ProStreetCamaro Offline
P
10W-30 Brad penn, VR1 or amsoil Z Rod. Absolutely no need for 20W-50 at all and with the correct oil no need for any additives either. Heck if you wanted cheaper oil Rotella T6 or standard rotella 15W-40 would work good also with no additives needed. 20W-50 does nothing but add drag to the rotating assembly. I have seen it cause an engine to sheer off a standard non hardened oil pump to distributor shaft.
Re: Head's spinning from what oil for 1970 chevy LT-1 [Re: Traction] #3366692 05/09/14 01:22 PM
B
bubbatime Offline
B
Valvoline VR1 10W30 is readily available and cost effective. I would try that and see how the engine likes it.
Re: Head's spinning from what oil for 1970 chevy LT-1 [Re: Traction] #3366744 05/09/14 02:00 PM
A
A_Harman Offline
A
Nix on the 20w50. I doubt that GM specified anything thicker than 30 for that engine when it was new.
Valvoline VR1 10w30 conventional.
Or buy a bottle of ZDDPlus and use it to supplement any good SN 5w30 synthetic.
2008 Dodge Ram 3500 diesel/G56
1985 Z51 Corvette track car 355/6-speed
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel/NV4500+GV
1972 GMC 1500 shortbed project truck 307/SM465
Re: Head's spinning from what oil for 1970 chevy LT-1 [Re: Traction] #3366904 05/09/14 04:50 PM
B
bigt61 Offline
B
You can't go wrong with the M1 15W-50 unless you're trying to start it in zero degree weather all the time. I don't think that old LT1 cam was so radical that 0W-40 or even 5W-30 wouldn't work in the M1 flavor. Defy is also a good choice.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
