I own a newer eXmark Lazer with the new Big Block EFI KOHLER engine (ECV940).
Had some minor issues with oil pressure sensor sampling rate. Would kick EFI into limp mode when hot started and 10W-30 was super hot. The hot/thin oil wouldn't generate enough oil pressure quick enough and the sensor would sense this and go into limp mode.
eXmark and Kohler addressed this by telling me to use 20W-50 oil and they also adjusted the rate at which this sensor reads the pressure.
In any event, I want to ensure this engine lasts 2-3K hours. And if it fails, I don't want Kohler engineers pointing to a X-Brand oil filter saying it was the cause of oil starvation or any other issues. So, I've been using the OEM Yellow KOHLER 52 050 02 Oil Filter going on 300 or so hours. I'd continue to use this filter, but I keep reading that this filter is made in India and is of VERY poor build quality??? Read about internal plastic parts breaking loose and causing MAJOR engine damage.
Can anyone give me assurance that I'm not harming my engine by running this filter?
Are there any suggestions for aftermarket?
This may sound funny, but I really don't want to go with a black colored filter. I write date and hours with a sharpie on the filter so I can track OCI's.
I can go with a longer filter, as it is upside down mounted and sits vertically right on top of the engine. This engine runs 3 qts and it DOES use oil (apparently a trait of the 999cc Kohlers).
I'll stick with the OEM filter unless someone can confirm that these filters are causing catastrophic engine failure.
I'm running 100hr OCI's and using Amsoil 20W-50 synthetic.
Thanks for any help or suggestions.
