Carquest Premium Air Filters = Wix?
by mclasser
02/23/17 04:52 PM
Transfer case lubricants
by Bronco1
02/23/17 04:33 PM
Any actual numbers on Pen Ultra vs Platinum?
by FlyingTexan
02/23/17 04:10 PM
Valvoline Max Life 50/50 Antifreeze @ Menards
by nascarnation
02/23/17 03:22 PM
Any Reason To Go Out of Way to Source Castrol 0w30
by BTLew81
02/23/17 02:45 PM
K&N Performance Oil Filters and Extended Drains
by mclasser
02/23/17 02:19 PM
Diff Oil recommendation for 2006 Range Rover
by kinch1
02/23/17 02:10 PM
Oil filter look-up
by JoelB
02/23/17 01:29 PM
What is the right price for this Suburban??
by Phishin
02/23/17 01:28 PM
Looking into rotors - Dura brand?
by wing0
02/23/17 12:31 PM
PQI test
by meborder
02/23/17 12:07 PM
oil suggestion/experienc
e with GMC Canyon 2.5l
by geekster
02/23/17 11:37 AM
Mobil1: Turbo Diesel Truck vs. Delvac 1 ESP?
by AirBull
02/23/17 10:47 AM
Under valve cover 2015 R18 doing #4 service
by Marco620
02/23/17 09:55 AM
Mobil1 5w30 Annual Protection?
by AirBull
02/23/17 09:06 AM
2005 Malibu "power steering" came across display
by 2James1
02/23/17 08:05 AM
Reducing noise in a Nissan VQ35HR
by Headgasket
02/23/17 07:53 AM
Oil Recommendation - 1990 Nissan 300ZX TT
by BobThe
02/23/17 07:29 AM
How to remove oil filter & not get covered in oil
by Cuba
02/23/17 07:18 AM
AC Delco PF46/Wix 51042XP Super Size Options?
by Egg_Head
02/23/17 06:25 AM
old_kodger, Eason111, Cuba, M54B30, killahurtz
60614 Registered Users
96 registered (901Memphis, Astro14, aquariuscsm, 4WD, Bandito440, Alfred_B, 10 invisible), 2170 Guests and 17 Spiders online.
60614 Members
66 Forums
261465 Topics
#3354188 - 04/26/14 09:09 PM Where does lost oil go???
cfree5119 Offline
Loc: Orlando, FL
For the guys running an extended life synthetic, specifically Mobil1, where does the lost oil go when you have add 2 quarts over the 10,000 miles? I would have to think it's built up on the engine somewhere? Please advise. I am leery of the extended life oil change intervals even with a filter change at 5,000 miles. Thanks.
#3354190 - 04/26/14 09:15 PM Re: Where does lost oil go??? [Re: cfree5119]
zrxkawboy Offline
Loc: SD
It has either leaked out or been burned.
"Think of all the Ford owners who will someday want an automobile." John Dodge
#3354192 - 04/26/14 09:19 PM Re: Where does lost oil go??? [Re: cfree5119]
Realtech214 Offline
Loc: Florida
I like OCIs of ~6000 miles. Thats by my OLM. A lot of cars will burn oil until the engines hot, the rings expand when hot.
#3354214 - 04/26/14 09:41 PM Re: Where does lost oil go??? [Re: cfree5119]
cfree5119 Offline
Loc: Orlando, FL
Burns oil and goes where? Out exhaust?
#3354223 - 04/26/14 09:50 PM Re: Where does lost oil go??? [Re: cfree5119]
Mackelroy Offline
Loc: Florida /Texas
Yep, if not leaking on the ground its going out the exhaust.
Now the question comes back to acceptable oil burn, in 8 to 10,000 miles even the tightest motor will normally use a 1/2 quart or so.
Then you have loose motors that may burn a quart every 3,000 miles. That or any worse I consider an oil user to an oil burner.
#3354233 - 04/26/14 09:58 PM Re: Where does lost oil go??? [Re: cfree5119]
HTSS_TR Offline
Loc: Lake Forest, CA
My 2000 E430 consumes less than 8-10 oz in 12-13k miles OCI. The 1994 LS400 consumes about 1/2 quart every 4-5k miles.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#3354263 - 04/26/14 10:24 PM Re: Where does lost oil go??? [Re: HTSS_TR]
Electrajoe Offline
Loc: Texas
If I quart low at 5,000 miles, you could need an oil change.
"Bought a Harley, bought a Honda, sold the Harley
CRASHED the Honda (motorcycle), bought the E350"
#3354301 - 04/26/14 11:18 PM Re: Where does lost oil go??? [Re: cfree5119]
bubbatime Offline
Loc: South Florida
It's over a 1000 degrees in the combustion chamber and there is a thin coating of oil on the cylinder walls that gets vaporized in the process.
13 Yamaha XT250 Valvoline Motorcycle 10W40
10 Acura TSX 2.4 Mobil 1 5W30 syn
09 Chrysler TC 4.0 Chevron 10W30
06 GMC Sierra 4.8 Chevron 10W30
#3354356 - 04/27/14 03:16 AM Re: Where does lost oil go??? [Re: bubbatime]
01_celica_gt Offline
Loc: St. Louis, MO
Sounds like the NOACK test testing at 250 is pointless if it is a 1000 degrees...wow just...
Red/Black 01 Celica GT 1ZZ-FED(Rebuilt @ 211/144) @ 211/145k
Red 02 Corolla S 1ZZ-FED(Rebuilt @ 140k) @ 141k
All Autos!
#3354508 - 04/27/14 09:37 AM Re: Where does lost oil go??? [Re: Mackelroy]
A_Harman Offline
Loc: Michigan
I think that sums it up nicely. However the engine comes to burn the oil, whether via rings, valve stem seals, or PCV carryover, it ends up going out the exhaust.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
#3354535 - 04/27/14 10:37 AM Re: Where does lost oil go??? [Re: cfree5119]
DBMaster Offline
Loc: Greg Abbott Land
I think lots of it must end up on the ground. Look in the spaces in any parking lot. Also, look at any dip or irregularity in a city street surface. There are always dark patches where some automotive fluid was shaken off.
#3354600 - 04/27/14 12:16 PM Re: Where does lost oil go??? [Re: cfree5119]
TiredTrucker Offline
Loc: Central Iowa
Surprising the amount that gets caught up in the PCV flow. Lot of oil in misted form from agitation inside an engine. I have a PCV oil catch can on my pickup engine. In 10,000 miles, I have only used, maybe, a quart. In that same time frame, the PCV oil catch can has captured almost 16 oz of of junk out of the PCV line from going to the intake. Can only imagine how that would have looked coating the intake valves, etc.
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
#3354635 - 04/27/14 12:51 PM Re: Where does lost oil go??? [Re: cfree5119]
Gokhan Offline
Loc: Los Angeles, California
Usually it's bad valve-stem oil seals but could also be rings in engines that are in really bad shape. It could also be the PCV line if the PCV valve is stuck or you overfill. Then there are leaks.
Base oil burns and gets out of the exhaust but some of it becomes varnish and gunk. On top of that the metal additives (detergents, moly, etc.) don't burn and form oil ash. Some of the oil ash permanently remains in the cylinders and on the spark plugs. Also, some additives, especially ZDDP, are poisonous to the oxygen sensor and catalyst, and reduce their lives. With diesel particular filters (DPF), ash going through the exhaust end up being caught in the DPF, eventually helping to clog it. For that reason, for DPFs, they require newly introduced low-SAPS oils (ACEA Cx categories) that are not readily available in US as there are few diesels here.
1 qt in 5k miles is a little high but not bad at all. I would have liked it to be less than 1 qt in 10k miles, but hey, everything in life experiences wear and tear and therefore slowly but constantly ages.
1985 Toyota Corolla LE, 4A-LC engine, ~ 265,000 M
Mobil 1 (M1) 0W-40 SN synthetic
Toyota 90915-YZZF2 filter, 90430-12031 drain gasket
