Originally Posted By: Wilhelm_D
Originally Posted By: ZeeOSix
Why don't you just take the oil filter off your car and plate off the mount because apparently in your mind it doesn't matter if you filter the oil or not.
Since I have not said that, it would appear you've run out of anything worth saying.
Keep grasping.
The small tears in the filter media
should have no material effect on the filtration. They are miniscule in comparison to the oil that goes through the bypass, and miniscule in relation to the total filter media area.
This hole in the media surely couldn't have any effect on the filtering performance of the filter.
Anyone with any technical logic would know a hole this size will pass WAY more unfiltered oil in 5,000 miles than the bypass valve would while opening rarely over 5,000 miles. Plus there was a similar hole on the other end of the pleat. Yeah, just a "trivial" tear or two.
I have already noted an actual oil analysis from a vehicle the Purolator made filter of which exhibited these tears, an oil analysis which indicated NO effect from the tears on particulates or engine wear.
Those are those the facts.
Yeah, and how do you know when that tear occurred? Was it at mile 1 or at mile 5,000? Where's that fact?
And where's your fact and proof that some of that torn media didn't go down into the engine. Can you account for every free fiber on the torn edge and if it dislodged or not? No.
