Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
129 registered members (4WD, 69Torino, AdditiveOCD, 2015_PSD, 2K2AcuraTL, 11 invisible), 1,707 guests, and 48 spiders.
Topics296,749
Posts4,958,204
Members66,964
Most Online2,577
Jan 14th, 2019
C4 in place of C3? #3350439
04/22/14 06:17 PM
04/22/14 06:17 PM
Australia
supercity Offline OP
Australia
Looking at Lubrizol's spider chart it would appear C4 covers C3 and only differs in exhuast after treatment compatability. That makes sence as C4 is essentially a lower Saps version of C3. I can't help but think it will not protect as well but thats not what the specs state.
So would a C4 oil work just as well as C3 in a C4 application? I realise the oil change interval may have to be lower.
Re: C4 in place of C3? [Re: supercity] #3350478
04/22/14 06:54 PM
04/22/14 06:54 PM
Great Lakes
Quattro Pete Offline
Great Lakes
There is a lubrication engineer on another forum that I frequent. He works on performing the actual tests on oil in order to determine compliance with some of the Euro mfg specs. He claims that the low SAPS versions of the oils do in fact result in more engine wear (less protection), however, it's still low enough that it meets the required spec.
So basically, the low SAPS versions just barely meet the wear limits while the full SAPS versions don't come anywhere near the limit.
I asked him whether you'd actually see a noticeable difference between the two over the life of the engine. He said that by 200K miles you would.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: C4 in place of C3? [Re: supercity] #3350515
04/22/14 07:24 PM
04/22/14 07:24 PM
Atlanta,GA
BMWTurboDzl Offline
BMWTurboDzl  Offline
Atlanta,GA
I would think the engine would have to be designed for C4 since it requires lower levels of Phosphorus. On plus side NOAK must be under 11 vs 13 for C3.
'15 435i - BMW branded Shell 0w30.
Prev
'10 335d
'06 330i
'03 330i
Re: C4 in place of C3? [Re: Quattro Pete] #3350525
04/22/14 07:35 PM
04/22/14 07:35 PM
Fredericksburg, VA
JAG Offline
JAG  Offline
Fredericksburg, VA
Very interesting.
Re: C4 in place of C3? [Re: Quattro Pete] #3350599
04/22/14 08:33 PM
04/22/14 08:33 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
I sold in Europe Peugeot 1.6HDI that was used in business I have there with around 450,000 km which is close to 300K miles. C3 oil was always used, and engine on a car was still a bomb.
15' Toyota Sienna AWD (Mobil1 0W20 EP+ 2qt of M1 0W40 + FRAM Ultra).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: C4 in place of C3? [Re: edyvw] #3350802
04/23/14 05:46 AM
04/23/14 05:46 AM
Great Lakes
Great Lakes
C3 isn't exactly low SAPS. C4 is.
Re: C4 in place of C3? [Re: Quattro Pete] #3350957
04/23/14 09:03 AM
04/23/14 09:03 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
Well, I did not take a look at limits. I know M1 ESP is considered low-saps but meets C3.
Re: C4 in place of C3? [Re: supercity] #3350968
04/23/14 09:11 AM
04/23/14 09:11 AM
Great Lakes
Great Lakes
C3 has an SA limit of 0.8%.
C4 has an SA limit of 0.5%.
Re: C4 in place of C3? [Re: Quattro Pete] #3350996
04/23/14 09:30 AM
04/23/14 09:30 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
Oh well, I think M1 is 06%.
Re: C4 in place of C3? [Re: supercity] #3351032
04/23/14 10:24 AM
04/23/14 10:24 AM
Great Lakes
Great Lakes
Are you saying you used M1 ESP 5w-30 for 450K km in that Peugeot?
In any case, the guy wasn't saying that the engine would die at 200K miles. Only that there would be measurable wear that would result in less than optimal compression leading to loss of performance and oil consumption.
Re: C4 in place of C3? [Re: Quattro Pete] #3351103
04/23/14 11:51 AM
04/23/14 11:51 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
No, we used Total Ineo C3 5W30. I think it is 0.8% SA.
Re: C4 in place of C3? [Re: edyvw] #3351997
04/24/14 12:59 PM
04/24/14 12:59 PM
London, England
bigjl Offline
bigjl  Offline
London, England
The 1.6hdi/tdci lump us a nice engine but suffers from horrendous oil related failures in the UK.
Usually turbo related.
I do wonder if it is stop start urban running but running the oci out to the maximum without considering severe service which is the issue?
16 S350d LWB 25k Mobil Super 3000 XE 5w30
17 Smart ForFour Auto 6.5k Mobil 1 0w40 FS
Re: C4 in place of C3? [Re: bigjl] #3352056
04/24/14 02:13 PM
04/24/14 02:13 PM
England
riggaz Offline
riggaz  Offline
England
[/quote]
It's the injector seals that cause the problem. They leak, allowing combustion soot into the oil circuit which then clogs up the oil ways to the turbo as well as destroying the turbo bearings. It's really difficult to clean the carbon out of the engine as well so people change the turbo and then the new one fails as well. It seems to be more common on Fords than the other cars that engine is fitted to.
Re: C4 in place of C3? [Re: bigjl] #3352109
04/24/14 03:41 PM
04/24/14 03:41 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
hmm, among Pug guys in Bosnia, 1.6hdi has status of uber-engine. Most of the problems they were facing with was 2.0hdi. This engine literally never had any issues except regular maintenance.
Re: C4 in place of C3? [Re: BMWTurboDzl] #3358614
05/01/14 09:41 AM
05/01/14 09:41 AM
UK
weasley Offline
weasley  Offline
UK
The main differences between C3 and C4 (in the current 2012 sequences) are:
- Noack: C3 13% max, C4 11% max
- sulphur: C3 0.3% max, C4 0.2% max
- phosphorus: BOTH are 900ppm max, but C3 has a 700ppm minimum
- sulphated ash: C3 0.8% max, C4 0.5% max
All engine testing parameters, which includes tests for piston cleanliness, viscosity increase, oil consumption, sludge, valve train wear and cylinder wear in both gasoline and diesel engines are identical. The main engine wear test (OM646LA) has exactly the same pass limits as for A3/B4 and A5/B5.
There's no way you can say that C3 oils will outperform C4, because firstly they shouldn't be in the same engines and secondly there will be some C4 oils better than others, so a good C4 will outperform an average C3.
Horses for courses, as we say on this little island.
2017 SEAT Leon 1.4 EcoTSI 150 FR Technology DSG
2018 Volvo XC60 D4
2011 KTM 990 SMT
