Originally Posted By: Eddie
If the engine has an oil pressured system it is probably OK to use but, cirtanly not the best choice. If however, it is a splash system the I definately would not use it. Ed
Why?
What makes it a poorer choice than say SAE 30, which some of those splash-lubed engines call for?
Unless you are starting at 100C, the 15w-40 is probably thinner than the SAE 30, LOL
I'm with OVERKILL on this...Why ?
For 20+ years my Wheel Horse C121 bathed in 15W-40. It's mowed countless acres of land, plowed miles and miles of snow, and the Koler that spec's 30W is still strong as ever burning no oil. Inside the engine is as clean as the day it was born...well I guess the head & piston top isn't as born date but you get the idea...
Why?
