I have an older Maytag Plus top/bottom fridge and over the past 2 days have noticed food in the back is freezing. The temp dials for both the freezer and fridge are set in the exact middle; temperature as measured with an infrared gun is about 32 degrees in the back and 35-38 up front. normally it runs mid 30s in the back to about 40 up front.
I checked the condenser and it was absolutely plugged solid with dust/animal fur etc.
Question; wouldn't a plugged condenser cause it to run warmer and not too cold? If cleaning it doesn't solve the problem, I'll move on to other parts like the damper or the thermostat control.
thanks
thanks
