Here is a Motorcraft FL-910s filter that I cut open. The filter is off a 2009 Ford Escape 4 cylinder that is owned by a friend of the family. I started doing the oil changes for her after we realized the quick-lube place had failed to change the filter. The vehicle sees mostly short trips around town. This OCI was 5,000 miles with Motorcraft 5w20 semi-synthetic.
The filter looks pretty good for this OCI, and since they are $3.97 I will keep using them. The fill that went in this vehicle was PYB 5w20 and the same filter.
