How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
105 registered members (aquariuscsm, ArrestMeRedZ, 69Torino, 4WD, 94astro, Astro14, 11 invisible), 2,311 guests, and 64 spiders.
Topics286,017
Posts4,900,844
Members67,548
Most Online2,967
Mar 10th, 2019
VW 068 115 561B Filter #329323
09/28/04 06:07 AM
09/28/04 06:07 AM
Haddonfield, NJ
SJUMBA Offline OP
SJUMBA  Offline OP
Haddonfield, NJ
I just picked-up a VW 068 115 561B oil filter from my local VW dealer today. The cost was approximately $9.50.
This is the "over-sized" filter that is now supposed to be used on the 1.8T engine. It is my understanding, that because of it's size, it increases total oil capacity and partially addresses the sludge issue with these engines.
On the filter it is stamped made in the USA. Does anyone have an idea who manufactuers this filter? Is there a "generic" equivilant?
Re: VW 068 115 561B Filter #329324
09/28/04 06:34 AM
09/28/04 06:34 AM
New Brunswick
55Test Offline
55Test  Offline
New Brunswick
Yeah, use whatever filter you want. Unless they specifically state that you must use only that filter, and supply it to you for free under the Magnusson-Moss warranty act, you are free to use whatever filter you like.
Re: VW 068 115 561B Filter #329325
09/28/04 06:49 PM
09/28/04 06:49 PM
RI
Steve_RI Offline
Steve_RI  Offline
RI
The OEM Mann filters are typically made in Germany, I think? The old Mann number is W719/30; the new one is W940/25. It's my understanding that the W940/25 fits older VW diesels, so it's not really new, so-to-speak. The other OEM is Mahle, but I'm not sure of the part numbers. I think Mahle OC105 is the W719/30 equivalent?
There are a few quality substitutes that can be found locally that are even a little bigger than the newer VW filter recommended. Among them are Napa Gold 1333(Wix), Wix 51333, and PureOne PL40316. The PureOne filter is a Mann filter, which is W950/4 if you are looking for the Mann specifically. It looks like that filter fits a lot of Volvos.
I'm on the last of my ten pack of W719/30's, so I've been looking into this. These filters were made in Germany.
Re: VW 068 115 561B Filter #329326
10/01/04 09:26 AM
10/01/04 09:26 AM
indy
dB Offline
dB  Offline
indy
My old Audi generally would use a Mann 719/5. Since I've been going long oci's, I've been using the 719/30 (actually the oem VW/Audi stamped version). My A4 (30V V6) uses the larger -J long-life filter. I'm trying it on my old Audi since it's a little larger (but it's $10). The thing that bothers me is that the "new" diesel filter replacement is not of the new 2yr/30km type filters that VW/Audi have been going to. I wonder if that will be a problem for long oci's? I'd use the diesel filter if I had confidence in it's long oci use.
Re: VW 068 115 561B Filter #329327
10/01/04 02:26 AM
10/01/04 02:26 AM
Oregon
Bill Kapaun Offline
Bill Kapaun  Offline
Oregon
quote:
Not exactly-
If you use a size that isn't "approved" (even though ALL the other specs are the same) by the filter manufacturer, they would have a way to get out of any warranty claims.
IF they would use that as an excuse?? Who knows??
Re: VW 068 115 561B Filter #329328
10/03/04 03:08 AM
10/03/04 03:08 AM
Washington St.
Ken2 Offline
Ken2  Offline
Washington St.
I prefer buying Mann, Mahle, (German) Bosch, or Hengst. The quality is absolutely tops. There are better ways to save a coupl'a bucks.
Ken
Re: VW 068 115 561B Filter #329329
10/13/04 09:53 AM
10/13/04 09:53 AM
RI
Steve_RI Offline
Steve_RI  Offline
RI
fyi..there's an official TSB (17-04-01) out now that specifies that part number (068 115 561B) as the filter to be used for all 1.8T Passats.
Re: VW 068 115 561B Filter #329330
01/30/05 12:02 PM
01/30/05 12:02 PM
Sudbury, Ontario
srivett Offline
srivett  Offline
Sudbury, Ontario
I just opened one up for fun and the ADBV has Parker on it. I just had another look on it and there is an XND USA on the filter as well. Perhaps it wasn't German quality after all.
The reason I opened it up was that for the first time after 380,000 km I switched to synthetic 0w40. After 7500 km there was nothing to be seen in the oil filter. Well, the engine is diesel so there's nothing but black to be seen. No sludge or chunks of stuff at all.
Steve
Re: VW 068 115 561B Filter #329331
03/09/05 12:32 PM
03/09/05 12:32 PM
Sudbury, Ontario
srivett Offline
srivett  Offline
Sudbury, Ontario
Does anybody know which filter would have the best ADBV in this application? The filters in my engine appear to be prone to syphoning because they are always 1/4 low when I remove them. If I don't let my engine idle for a while in the morning I can hear the lifters get a whipping from the cams for the first 100 feet. [Frown]
Watching the oil pressure light blink for a few seconds after every startup is also getting pretty old, I have to rev the engine a bit to get the alternator going so I'd like the pressure to come up sooner. I don't rev the engine until the oil light goes out.
I am currently using a white WIX filter. It seems to be equal to OEM for noise.
Thanks, Steve
Re: VW 068 115 561B Filter #329332
03/16/05 11:44 AM
03/16/05 11:44 AM
Sudbury, Ontario
srivett Offline
srivett  Offline
Sudbury, Ontario
clack CLACK clack CL CL CLACK [Duh!] I think I need a preoiler. The noise is downright embarrassing. [Frown] Anybody make a filter with an electronic ADBV? These rubber contraptions just aren't cutting it.
Cheers, Steve
Re: VW 068 115 561B Filter #329333
03/16/05 11:49 AM
03/16/05 11:49 AM
California
nthach Online content
nthach  Online Content
California
Steve
Wix seems to be using the same Parker ADBV as well.
Re: VW 068 115 561B Filter #329334
03/16/05 04:59 PM
03/16/05 04:59 PM
Dixie
TooSlick Offline
TooSlick  Offline
Dixie
I order these oversized oil filters from "blauparts.com" - an Independent Audi place up in WI. Order three at a time and they are only $5.95 each. I can use these filters on both my 2.3L, Audi 100 and Audi TT w/ the 1.8L turbo.
The Mann filters are about the best I've seen in terms of quality. Just look at the number and precision cut of the threads and the absence of burrs. The wall thickness of the canisters is very impressive as well.
TS
Re: VW 068 115 561B Filter #329335
03/16/05 11:08 PM
03/16/05 11:08 PM
Texas
Filter guy Offline
Filter guy  Offline
Texas
Champion Laboratories has the contract for VW/Porche/Audi and builds the OEM filter for the engine plants in North America. That's why it says Made in the USA.
Re: VW 068 115 561B Filter [Re: SJUMBA] #4672280
02/20/18 07:07 PM
02/20/18 07:07 PM
pa
benjy Offline
benjy  Offline
pa
sounds good, but squeezing the older smaller filter down past everything on my 2001 TT 225Q is tough enough, is this filter just longer, fatter or both
Re: VW 068 115 561B Filter [Re: benjy] #4672669
02/21/18 04:21 AM
02/21/18 04:21 AM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
Dude, 13 years later smile
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
