Originally Posted By: Danh
Be careful here. If you have the Owner's Manual is probably says Mercon is specified - it is on my 2005 anyway with specific instructions not to use Mercon V. Since then, Motorcraft has reformulated Mercon V to be compatible with this tranmission and Motorcraft no longer makes plain Mercon.
So the question is are other manufacturer's Mercon V products compatible with your transmission or is it the orginal, non-compatible Mercon V formula?
Under the circumstances, I'd either get Motorcraft Mercon V from Ford dealer or use a name brand Mercon, like Castrol. Perhaps these fears aren't well-founded, but I'd stay away from MaxLife after it was found not to meet manufacturers specs by the PQIA and avoid ATF products that try to be too "universal".
The CD4E in the Escape doesn't have a great reputation for durability, so fluid choice should be considered carefully.
That TSB/Thinking was superseded in '07 when they reformulated Mercon V to be backwards compatible in ALL Mercon circumstances. If your worried, I'd have used Maxlife. Its closer to the older Dex Merc while still being a better syn fluid.
