hey guys,
Well I did decide I wanted the M1 filter for the 03 Civic EX and I did some searching and found out about how Honda is using a new smaller filter. The guy at the parts counter said I needed an M1-110 and I checked on here and that was one that could be used. I also saw that the MI-104 was also one that could be used (I think its the same one as on my Jeep?) I was pretty sure I read they are 100%, no questions asked interchangeable and even Honda says so.
I also saw the M1-105 and M1-107 mentioned but was immediately ruled those out because I saw where it had different specs for the bypass.
So what i'm asking is should I go ahead and get a M1-104 or get the smaller M1-110? I don't want to have any fit issues. I may not end up changing it the Honda dealer in town will do it for 10 bucks if I bring my own oil and filter. I don't have a car lift and I can't fit under the car.
Is there any advantage to one or the other? Improvement coldstart with the smaller? or is the M1-104 better all around?
Thanks for any help or advice,
Seth
PS- I'm going with the M1 0w20!
[ August 26, 2004, 02:32 PM: Message edited by: Seth_TJ ]
Seth
