Saying that oils are compatible means chemicals will not gell or precipitate out of solution. It does not mean they work well together.
Let’s say one oil uses chemical F for its high temperature anti-friction component. It works best at a particular concentration. It may be less effective at a lesser concentration, hence, one of the reasons that we need to change our oil. As you drive the component is used up, the concentration decreases below a critical level.
Another oil may use anti-friction additive G to do the same function. An oil change is required as this additive falls below it’s most effective concentration.
If you mix both these oil together in a 50-50 concentration you will dilute each of these additives by half at the moment you start to run this oil concoction. It is unlikely that a few thousand miles down the road you have the appropriate protection you were expecting of your mix.
Further, even though a mix of several Base Oils of different grades may give you a close approximation of final viscosity, all bets are off when mixing fully formulated oils as again, components may start out at half strength. Some additives do no do their intented task on a linear scale. A certain minimum concentration may be needed for the additive to begin to do what it was designed for.
I do not like mixing motor oils of even the same brand.
aehaas
aehaas
