I apologize for my english;
I have a Fiat Bravo (2008) 1.6l turbodiesel multijet 120 HP (88 kW).
Recently I got rid of the Diesel Particulate Filter, so the ECU has been reprogrammed, also to obtain more power and torque.
On BITOG, in the document: "Putting the Simple Back into Viscosity" I read:
Load
Equipment loads must also be considered when selecting the proper lubricant viscosity. Under a heavy load, the lubricant film is squeezed or compressed. Therefore, a higher viscosity lubricant is needed
I think my engine works "under heavy load" because of high torque at low RPM
The OEM recommends this: Selenia (Petronas) WR PE 5w-30 ACEA C2 which has Kinematic Viscosity @ 100°C = 10.2 cSt
Do I need a "thicker" oil? If the answer is Yes,
is it sufficient a SAE 30 with Kinematic Viscosity next to the top of the spec (12.5 cSt) or it is better a 0W-40?
I found at a very good price this one:
Shell Helix Ultra Extra 5w-30 Kinematic Viscosity @ 100°C = 12.02 cSt
Meguin Compatible 5w-30 Kinematic Viscosity @ 100°C = 12 cSt
More expensive:
Castrol Edge 0w-30 Kinematic Viscosity @ 100°C = 12.3 cSt
Castrol Edge 5w-30 Kinematic Viscosity @ 100°C = 12 cSt
Obviously, a choice based only on kinematic viscosity is incomplete, but I don't know what additives are in a specific oil, what base is used, ecc.
Than you very much fot the answers
Simone
Load
More expensive:
Simone
