I recently began using Motorcraft Silicone Paste for brake caliper slide pins and am running into a problem. I believe it’s very similar to the 3M silicone paste product.
The stuff is quite thick. On cars with brake caliper slide pins that remain on the bracket and have boots attached to them, I am having problems with the boots binding up.
Here is the situation that arises: I would put a moderate amount on the slide pins and reinsert the pin into the bracket. The boot stays with the bracket and is not taken off with the pin.
When I try to “exercise” the pin and boot together after lubing, the boot becomes full of air and the pin binds up and cannot slide.
Someone suggested that I “burp” the air out. So, I tried lifting up a corner of the boot with a pick and let all of the air out. When I do this the boot then sticks to the pin like a skin.
So, what’s the issue here? Grease too thick and sticky? Or technique.
I don’t remember having this issue before but then again, I did not start dealing with this style of calipers until recently.
Thanks.
Thanks.
