Hello all, hope the new year is treating you well.
I have a question someone might be able to help out with.
I have a Kubota Tractor L245DT, and it needs the trans/rear axle/hydraulic oil changing. The manual has the note that early L series tractors had 80W oil installed in the trans, but that this should be changed to Kubota UDT soonest.
(I have had this machine for a few years now, and this is the first time I have changed this oil, I have no idea what is in there currently)
Here is the problem.
I have several options to replace this oil, Kubota UDT IS one of them, but (very)expensive, and some of the other suppliers have oils the meet the UDT standard...however.
Gulf Oil for example, Universal Tractor Transmission Fluid, listed as suitable, is rated at 80W.
Fuchs Titan UTTO (Universal Tractor Transmission Oil) also listed as suitable, is rated 10W30.
Castrol Agri Trans MP is rated at 20W40.
Seeing as how Kubota recommended ditching the 80W as per the manual, which way do I go?
There is a big difference between 80W and 10W30.
Temperatures here rarely get below freezing (Celcius) and normaly range between 5 and 30 deg C.
Can anyone shed some light on this?
Regards,
Scott.
Regards,
Scott.
