Originally Posted By: Hsnberg
The pictures on the bottle are pretty dramatic, and I wasn't sure whether to believe it. The entire "fluids and chemicals" section at Autozone totally reeks of "snake oil."
They typically will work in those situations. The question should really be whether or not an engine suffers from an issue that can be solved by one of these products.
A lot of marketing is really about convincing buyers that they need a particular product. If one consistently uses a high detergent gasoline, then megadose fuel system treatments are unnecessary. Sometimes I use small doses of Red Line SI-1 when I use a gasoline that may not be Top Tier or otherwise high detergent.
Shampoo makers have convinced customers to use it twice to get a good lather, even though lather doesn't necessarily mean cleanliness. It's mostly marketing.
