Originally Posted By: IndyIan
True 4wd does help as sort of mechanical ABS. All cars have huge front brake bias, so you will always lock a front tire first before your back tires approach maximum braking, especially on ice and snow. 4WD equalizes tire speeds on both axles so both axles can achieve maximum braking. On the Tracker I'm sure it cuts braking distance by 10-20% but it does sacrifice some stability as now both ends lose grip together allowing the back end to slide sideways. Probably some of the reason so many 4wd cars end up in the ditch... A fwd with lawn dart handling give you a warning with locking the fronts first so you can back off the pedal without any sort of steering input required. A slightly sideways SUV at 60mph on ice or snow isn't too tolerant of an over correction and takes some guts/skill not to panic and drive out of it.
Interesting. I hadn't thought about that before, but it makes sense for any true 4WD without a center diff. My Mazda3 seems to brake as good or better than any trucks or cars I've driven in winter conditions, even with my tires nearing the end of the winter tire phase of their lives. The difference is almost certainly due to the more advanced variable brake force distribution.
