For using 2 stroke as an upper cylinder lubricant does it matter if it is tc3w or not. I'm assuming the only difference is the marine version has less pollutants thereby leaving less deposits in your engine. The Interceptor sounds very interesting. Heard that the Dominator stuff is good as well. From what I can understand the key is the resistance to burn off in the combustion. The more oil that is not burned the better lubrication the piston walls receive...
From my experience I can say that the combustion is better in fact all the black carbon on the exhausting pipe has gone.
The mileage has improved too, with tcw3 I did not see any improvement.
