First off, welcome to the forum!
Originally Posted By: TAvsGN
Any thoughts?
Avoid those bulbs at all costs. They are simply blue-painted Chinese bulbs that will produce less light than the ones you have in there now and probably half or a third of the life. And although you have no guarantee of poor material and manufacturing quality here, I'd say it's probably a safe assumption that it'll come with the deal.
I recommend buying bulbs only from first-tier bulb manufacturers, like Osram/Sylvania, Philips, GE, etc. Many (like PIAA and EiKo) are simply bulb "labelers", putting their names on others' bulbs. Maybe they're good quality, maybe they're not. With a true no-name bulb like what you are considering above, you have nothing to gain.
If you have to have a blue-coated bulb, I would recommend the Sylvania Silverstar. Your lighting performance won't be any better than it is now, and you'll be paying quite a bit more for a bulb that will likely burn out sooner, but at least you know the material and manufacturing quality will be good.
