Originally Posted By: chad8
Extended Storage Life: Properly treated with PRI-G, your gasoline will stay fresh in storage for months and even years at a time. Super Concentrate PRI-G Complete Gasoline Fuel Treatment You’ll be assured a fast start next season simply by treating your fuel with PRI-G prior to storage. PRI-G goes a step further, actually restoring old fuel to refinery-fresh conditions. If you are storing gasoline for any period of time, you can’t afford to be without PRI-G.Keeps Fuel Fresh and Ready To Use
– It’s a fact: fuel ages quickly! No matter how soon you use the
gasoline you buy, it will have aged in your fuel tank by the
time you use it; for that reason, you can’t afford to be
without
PRI-G
PRI-G
keeps gasoline fresh. In fact, by treating the fuel annually with
PRI-G,
you can
keep it fresh
in storage for years! You’ll be assured a fast start fo
r your engine next season, or whenever you use it next.
Those operating a generator on a period
ic basis are especially benefited by
PRI-G
use – when it comes time to
run that generator, it’s fuel will be fresh
and ready to go! If your fuel has already aged,
PRI-G
can still help. Tests
have shown where
PRI-G
can restore aged fuel to refinery-fresh conditions
This is just not true. PRI-G may do a great job stabilizing gas but no chemical can bring back old gas. I asked Chevron tech support this very question a few years ago. Short of re-refining gas, nothing can help. So I just avoid anything PRI-G.
