Originally Posted By: Spazdog
Then they are willing to give up the warranty work for low end Craftsman and Toro stuff.
MTD makes the low end residential machines for Sears and Toro.
The OPE shop I use told me that Toro had the easiest warranty claims. Even on the big box affordable stuff.
Even if the warranty is more difficult than Toro, they are giving up on Troy-Bilt warranty revenue.
Briggs and Stratton supply the WalMart stuff. (Murray and Snapper....but in all fairness, you can tell at a glance the difference between a WalMart Snapper and a commercial grade Snapper just in quality and comfort of the hand controls)
Toro does have an excellent warranty claims process, and takes care of their customers at all price points.
Only their low end conventional riding mowers are made by MTD though. The pushers are still in house, even the entry level Lawn Boys. Even though it's built to be sold at Home Depot or wherever, it's still much higher quality and better engineering than MTD.
MTD products have their place, can often get the job done, and can generally be rigged up so they stay working, but I can see why an OPE shop wouldn't want anything to do with them. They can be difficult to repair because they are not designed to be repaired, and it's quite easy to "total" one out.
I used to "recondition" mowers that had been returned to stores for one reason or another. A lot of nearly new MTDs went in the scrap metal pile. Beyond missing/damaged hardware or a stuck carb diaphragm they usually got junked. Even riding mowers got junked pretty easily.
AYP/Husqvarna made some real winners too under Poulan, Weedeater, Ariens (mowers only), and other names.
Kawasaki powered Toros are the best thing in the world to work on. If I had an OPE shop, my sign would say "Kawasaki powered Toros ONLY."
