Here's the situation: a guy drove around with his rear brake pads worn down to the metal. He's an older guy and I suspect his hearing isn't very good anymore. He kept driving around like this until one of the rear brake discs wore completely through. Once that happened he was able to feel that there was something wrong with his brakes. Now, he doesn't put a lot of miles on his car so as you can imagine there was plenty of time for a lot of iron filings to form a thick layer of rust on his wheels.
The brakes have been repaired since then but my boss also promised we'd try to clean up the wheels. I was not happy to hear that.
Anyway, it turns out that the boss man thought we could just use a little metal polish and rub the rust right off. I'm convinced that if we try that it will take a huge amount of time and the rust will act as a coarse abrasive and will destroy the paint on the wheels.
I picked up a 76 oz. container of super iron out on my way home today with the hope that this will get me out of wasting time ruining someone's wheels. A lot of you guys now tremendously more about both chemistry and detailing than I ever will so... any opinions or advice here?
Will it take the rust off? Will it damage the paint? If it could work should I brush on a paste or soak the wheels in a weak solution?
