Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
rorty, Ghosty, zmann96, yetti96, weekendwally
71602 Registered Users
51 registered members (BTLew81, c502cid, Aero540T, BrianF, BlakeB, 5 invisible), 1,388 guests, and 31 spiders.
Topics306,113
Posts5,287,768
Members71,602
AC Delco PF64 vs. PF48 #3223711 12/21/13 02:46 PM
N
NewC7 Offline OP
N
My new 2014 Chevy user manual say use AC Delco PF64 oil filter. Wal-Mart didn't carry it. I went to the local auto parts store and the sold me a AC Delco PF48 saying it was compatible.
I searched and confirmed the PF48 is listed as compatible with the PF64.
What is the difference between the 2 filters?
Re: AC Delco PF64 vs. PF48 [Re: NewC7] #3223751 12/21/13 03:10 PM
W
Warstud Offline
W
I'm sure the PF64 is a bit longer is all.
Re: AC Delco PF64 vs. PF48 [Re: Warstud] #3223758 12/21/13 03:16 PM
dave123 Offline
+1 but is the 64 a Ecore the PF48 is not.
I would run the PF48 and have on the wife's 2012 6.0L HD but now running RP10-48 and will be sticking with them.
Re: AC Delco PF64 vs. PF48 [Re: NewC7] #3223953 12/21/13 06:41 PM
J
jhellwig Offline
J
I duno what the pf64 is but the pf63 is the tall version of the pf48. And it is not an ecore.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: AC Delco PF64 vs. PF48 [Re: NewC7] #3224068 12/21/13 09:04 PM
J
jhellwig Offline
J
Ok I have now edumicated myself. According to baldwin the only difference is the gasket on the b7422(pf63) versus the b160(pf48). The b7422(pf64) is listed as a susuki application. Other than the gasket everything else is the same.
Gm must be using a susuki engine in something.
2014 Toyota Sienna
1983 Chevy K5 350
Re: AC Delco PF64 vs. PF48 [Re: NewC7] #3225714 12/23/13 05:45 PM
A
aussiek2000 Offline
A
What car/engine? A PF64 is OE on Corvette and Malibu 2.5. PF48 has the same threads and base size but a completely different bypass mechanism.
Re: AC Delco PF64 vs. PF48 [Re: NewC7] #3225813 12/23/13 07:23 PM
B
barkingspider Offline
B
I would use a pf64.
04 Avalanche Z71 4x4
Re: AC Delco PF64 vs. PF48 [Re: NewC7] #3225820 12/23/13 07:28 PM
N
NewC7 Offline OP
N
The car is a 2014 Corvette. The manual call fir a PF64. The audit supply store sold me a PF48. Their computer said the PF48 was equivalent to the PF 64. After some research, I returned it and they sold me a K&N 1017 filter foe $11. That is also equivalent to the PF 64.
I put on the K&N yesterday. Runs fine and pressure is the same.
All I really want to know what the difference is and will it cause any problems.
To add to confusion, the filter on from the factory has a PF63 label but the factory said some cars had filters with PF 63 labels but were in fact PF 64.
Very confused.....
Re: AC Delco PF64 vs. PF48 [Re: NewC7] #3225980 12/23/13 10:10 PM
J
jhellwig Offline
J
Eh nevermind. I should research before I post.
Just order some pf64's online.
2014 Toyota Sienna
1983 Chevy K5 350
Re: AC Delco PF64 vs. PF48 [Re: NewC7] #3226006 12/23/13 10:54 PM
B
B
The pf48 has the oil filter bypass valve inside and has a 22mm thread. I don't know if the pf64 has a bypass valve or not but it has the same threads. The pf 63 is like 3/4 inch longer than the pf63 and pf48.
Re: AC Delco PF64 vs. PF48 [Re: NewC7] #3226156 12/24/13 06:28 AM
A
aussiek2000 Offline
A
Very confused.....
There was a bulletin on this a couple weeks ago. Factory filter is a PF64. They were mislabeled "replace with PF63", but you should still put a 64 on it.
Re: AC Delco PF64 vs. PF48 [Re: NewC7] #3226159 12/24/13 06:31 AM
A
aussiek2000 Offline
A
#PIP5157: LT1 Engines May Have Been Built With An Oil Filter That Has An Incorrect Label - (Oct 17, 2013)
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
Some early LT1 engines may have been built with an oil filter that has an incorrect label on the can.
The filter is correct. However, the label is wrong.
Recommendation/Instructions
Replacement of the filter for the incorrect label concern is not necessary.
The technician needs to be sure to replace the OE filter with the correct PF64 when it is time for an oil and filter change.
The incorrect label says to replace the oil filter with a PF63. The correct service part is a PF64 part # 12640445.
Filter with the wrong label
Object ID: 3633899Click here for detailed picture of the image.
Filter with the right label
Object ID: 3633900
Re: AC Delco PF64 vs. PF48 [Re: NewC7] #3226251 12/24/13 09:09 AM
N
NewC7 Offline OP
N
Yes, I am aware of the label mix up.
My question is what is the difference between the PF64 and PF48? All the cross references says they are interchangeable.
I put a K&N 1017 in, which is also listed as interchangeable.
So, what is so special about the PF64 that Wal-Mart and my local auto parts store don't know about it.
Re: AC Delco PF64 vs. PF48 [Re: NewC7] #3226782 12/24/13 08:36 PM
Z
ZeeOSix Offline
Z
http://chevyavalanchefanclub.com/cafcna/index.php?topic=140690.new
http://www.chevymalibuforum.com/forums/showthread.php?t=27730
http://forums.corvetteforum.com/c6-corvette-general-discussion/3165118-pf48-vs-upf48r.html
Re: AC Delco PF64 vs. PF48 [Re: NewC7] #3230190 12/28/13 06:48 PM
A
aussiek2000 Offline
A
I assure you, they are not. We stock both for a reason. The 64 weighs about double a 48 and has a completely different bypass mechanism inside. If a 48 was the same, don't you think they would have used one.
