Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
The best in personal defense (Humor)
by StevieC. 01/15/19 11:10 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
96 registered members (Alfred_B, 53' Stude, 240_Ed, AandPDan, 97f150, advocate, 10 invisible), 2,212 guests, and 32 spiders.
Topics296,643
Posts4,956,486
Members66,950
Most Online2,577
Jan 14th, 2019
WD40 o rings ? #3203215
12/01/13 06:18 PM
12/01/13 06:18 PM
IL
Ndx Offline OP
Ndx  Offline OP
IL
Hey Guys,
Anytime I have to slide something with o ring I will lube it with WD40
A) it will not migrate like let say vaseline but it will evaporate
WD40 website says safe for rubber
I seen some diy test where orings were not affected after seating for 24hrs
Should I replace orings that I used WD40 on ?
Or not worry about it ?
Re: WD40 o rings ? [Re: Ndx] #3203222
12/01/13 06:26 PM
12/01/13 06:26 PM
Great Lakes
Quattro Pete Offline
Great Lakes
If I remember our last discussion on this correctly, according to the manufacturer of WD40, it is safe on o-rings.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: WD40 o rings ? [Re: Ndx] #3203226
12/01/13 06:27 PM
12/01/13 06:27 PM
ventura, ca
morepwr Offline
morepwr  Offline
ventura, ca
Your correct. The WD40 will evaporate off and wont hurt a thing. No worries.
Re: WD40 o rings ? [Re: Ndx] #3203237
12/01/13 06:50 PM
12/01/13 06:50 PM
Ga
DB_Cooper Offline
DB_Cooper  Offline
Ga
Originally Posted By: Ndx
Hey Guys,
Don't worry about it...anything is better than nothing and WD-40 is harmless. Personally, I use Vaseline. Vaseline melts at about 100*F and I have not noticed any mess. It disappears very quickly around a hot engine. Never had a seal/lip or "O" ring leak with Vaseline..(knock on wood)
Re: WD40 o rings ? [Re: Ndx] #3203331
12/01/13 08:46 PM
12/01/13 08:46 PM
ME
eljefino Offline
eljefino  Offline
ME
I've used motor oil on gas line fittings and the appropriate fluid (PS, ATF, etc) on everything else.
Probably too little to make any difference.
Re: WD40 o rings ? [Re: Ndx] #3203336
12/01/13 08:49 PM
12/01/13 08:49 PM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
O-rings are normally made of neoprene rather than rubber. Personally I would use a silicone based grease like Sil-glyde.
2015 Ford F250 w/Powerstroke
Re: WD40 o rings ? [Re: Ndx] #3203347
12/01/13 08:57 PM
12/01/13 08:57 PM
IL
Ndx Offline OP
Ndx  Offline OP
IL
Thx, should I replace them then ?
According to WD40,neoprene is not affected by it...
For all variations : WD-40 demonstrates none to negligible deleterious effect to plastic, rubber, and metal hard surfaces. This includes Acetal, neoprene/hard rubber, HDPE, PPS Copolymer Polysulfone, Teflon, Viton, steel, galvanized steel hot dip, electroplated, copper, brass, magnesium, nickel, tin plate, titanium, and zinc
According to msd there are some rubbers that will swell after prolonged exposure... Orings are pretty tight sealing stuff so I wonder if it will evaporate or because its tight its just gonna sit there ?
Re: WD40 o rings ? [Re: Ndx] #3220447
12/18/13 09:30 AM
12/18/13 09:30 AM
West Michigan
buck91 Offline
buck91  Offline
West Michigan
Is wd40 still Stoddard solvent, mineral oil and an evaporative carrier?
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
