That's on the low side of what I would call acceptable. Are you doing a lot of short trips? (where the alternator isn't running for very long to charge it up)
Take it to an auto parts store and have it tested for free.
I've found that OBD readers often show a lower voltage than a real meter. I've seen meters show 12.6 volts when an OBD reader is showing 12.2. Check it with a real voltmeter and see what that says.
heres a graph that represents the relative life of battery depending on voltage.
i'd replace your battery unless the CCA on there is significantley bigger than needed. Cold weather may put enough voltage drop so that you wont be able to start your car.
Originally Posted By: Ndx
thx guys that's very informative!
I will measure at the posts.
That's what I'd do and wait half an hour after turning the engine off to get the most accurate reading.
I recently had my Bimmer in to CTC for the required e-test.
When I picked it up, I don't know what they did but it was dead.
I suspect they left the ignition on some how.
They gave me a jump start and suggested I needed a new battery without testing it.
It's an older battery and does slowly loose it's charge more than a new battery would. It needs to be put on a charger if I'm not regularly driving it as is often the case in the summer months.
I only replace a battery if it fails completely.
Ndx, 3 years isn't that old so I don't think you should need to replace it but if you do I'll take it off your hands instead; I don't think you're far from me. I have a used battery I can give you for the trade-in.
My scanguage always reads mid 13's when my voltmeter shows a bit over 14v...running.
Also, what car? Some newer cars have "smart" alternators that reduce voltage to 12.5 volts under certain conditions. With no loads on the alternator and a fully charged battery, a newer car just may dial back the alternator if it can. Anything to save 0.1 gallons/hour...
