Originally Posted By: edyvw
Well, what I have observed in cold temperatures is that GC has much smoother start. Every time I start engine with M1 I can hear camshaft! That never happens with GC unless, car is not driven for 3-4 days. What I think is that GC has magnetic technology also, that is popular in Europe so molecules sticks to camshaft longer.
Anyway, I get what you saying about number, however in practice, it is different story!
I am kicking out this M1 at 3K, and going back to good ole GC!
Sounds like the marketing folks have gotten to you. GC doesn't have "magnetic technology", it probably has some esters in it (that are polar and cling to metal) just like Mobil uses in probably all of their oils.
What causes the sound difference could be one of the additives Castrol uses and perhaps Mobil doesn't. Mobil uses tri-nuclear moly for example, maybe Castrol uses something else that works to deaden sound on your particular engine?
My M5 doesn't care and makes no clatter on PU 5w-40 currently, even though it is significantly heavier than what I had in there last winter (M1 0w-40, which it also made no noise on).
So I would argue that "in practice" your statement about the numbers being a "different story" is more that your engine exhibits certain acoustic traits on M1 0w-40 that it doesn't on GC. There's nothing wrong with pointing that out. But it doesn't change the fact that GC likely isn't any thinner at -35C than M1 0w-40 is. And at higher temps, again, M1 0w-40, due to having a higher VI, is also thinner
No I am not persuaded by the marketing guys, however, I like to listen engine. I had same issue with M1 on passat 1.8T, and even now on 2.0T engine definitely developed more noise during cold start, as well as on high rpms.
So, that being said, going back to GC. Never failed so far, never had any issue with consumption or very strong gas odor (which M1 constantly has). Call me old fashioned, but when engine develops more noise using one oil compare to another, that is enough for me to stay away.
I just never understand why I occasionally still come back to give another shot to M1.
For that matter, in the spring i might give a shot to the PU 5W40 for the first time in CC.
