Originally Posted By: Quest
Only if you believe in those anecdotal posts here on BITOG.
Almost everything posted on BITOG is anecdotal. So, why do you even follow the forum?
BTW, have you ever used an upper cylinder lubricant?
I never believe in the claims/benefits of UCL, lubricating fuel pumps, etc. citing that if that is indeed the case/truth (RE: the need of UCL properties or lubrication to fuel pumps in general), then all the E-85 flex fuel vehicles sold during the past many years would have suffered from catastrophic mechanical failures already, from either repeatedly burned out fuel pumps, upper compression rings worn out (dramatic loss in compression, oil burning, etc.) or both.
Turn the calendar back a few decades. Lead in gasoline helped lubricate the valves and upper engine. Unleaded gasoline does not have this benefit. In the first few years of the 'unleaded era', there were plenty of engine problems. Eventually, the car makers got things sorted out.
Even before this, remember the era of smog pumps - a truly bad idea in automotive engineering. It was a quick fix to an environmental issue which caused all sorts of side issues, like burned valves, failed rings, etc.
As for E-85 flex fuel vehicles, I suspect more than a few of the early models had serious engine lubrication or premature wear issues. You may believe the car makers got it right the first time, but I wouldn't hold my breath. And, if we should switch to LPG/CNG for motor fuel, expect a whole new set of lubrication/wear issues.
I never add anything that claimed to have UCL properties or lubricates fuel pumps in all of the vehicles I own/owned or serviced. Never seen one failed yet...
Most vehicles should run okay without the addition of some UCL product. That does not mean that they might not run better or last longer if a UCL was added. Here's an MMO story that you are welcome to dismiss as an anecdote:
Many years ago, a part-time Army job took me by several area high schools with auto tech shops. At the time, I was driving a 1972 MGB-GT - straight-4 cast-iron OHV engine, upright, very accessible spark plugs. I had a Marvel inverse oiler mounted in the vehicle that was putting MMO into the engine at the rate of ~1 quart per 1000 miles (works out to ~1 quart per 40 gallons of fuel). The hose from the oiler (1/4" reinforced fuel line) went to a Tee - then down into the intake streams, just behind two side-draft SU carburetors. Typical engine cylinder pressures were in the ~165-170 psi range.
On several occasions, one shop teacher (who knew about MMO and inverse oilers!) demonstrated the following to his class: You could measure the engine compression. Next, you could block the oiler (pinch the hose - see that it stopped dripping). Drive the vehicle around the block. Measure engine compression again and it would drop ~6 pounds per cylinder. Finally, you could reverse these steps: unblock the oiler hose, drive the vehicle around the block again, measure the cylinder pressures again and they would be up again. If you work through the numbers, the increased cylinder pressures simply meant more power or greater efficiency. It also stopped valve burning.
The MGB-GT originally came with a smog pump (a truly bad idea) and it had a voracious appetite for exhaust valves - which is why I put an inverse oiler on in the first place. A grizzled old machinest in Sparta, Wisconsin knew about oilers and, after rebuilding my cylinder head at 20,000 miles, said that I really needed one. He was right, for more reasons than he knew. Clearly, another fix for the valve problem would have been to install better valves - a better grade of austenitic steel, nimonic or nimonic-80, titanium or sodium cooled. In fact, Leyland did upgrade their valve material by 1975 or so.
Upper cylinder lubrication was simply a solution to a known wear problem with L-head and flat-head engines. It worked. That's why the MMO folks have been in business since 1923. You're welcome to not 'believe' in UCL... and you are also welcome to believe the earth is flat.
