Originally Posted By: Ken2
There might be a few brake systems with elastomers that do not tolerate the borate esters in the DOT4 & higher brake fluids. These borate esters that raise the boiling point also do absorb moisture faster than plain polyglycol ether DOT3 fluid. There are some DOT3 fluids with a higher than minimum boiling point, but I do not know of a concise reference list.
The DOT 3 standard makes no specification of what proportion of materials is used. It specifies compatibility with specific materials, a dry boiling point, a wet boiling point, and a maximum viscosity at 100 deg C. I would be very much possible for a manufacturer to produce a brake fluid that meets DOT 5.1 specs but label it as a DOT 3 fluid. Some of the heavy duty DOT fluids probably do contain higher amounts of borate esters. There's nothing about the standard that deals with how fast it absorbs moisture or how long it lasts in a brake system.
I wouldn't rely on a label saying that it's "DOT 3" to tell me that it will last longer in a brake system without a flush.
