Replaced bulbs in Mag Lites
by tig1
11/24/17 03:16 PM
Ski Boat Oil
by Skier
11/24/17 03:09 PM
PYB 5w20 Sold Today
by Speak2Mountain
11/24/17 02:47 PM
building a house directly under CVG's flight path
by CincyDavid
11/24/17 12:51 PM
Best synthetic oil for 2010 Silverado 5.3 lc9 moto
by Sax
11/24/17 12:39 PM
How Do Viscosity Index Improvers Work?
by Red91
11/24/17 11:37 AM
Black & Decker Cordless Beater Batteries
by benjamming
11/24/17 11:06 AM
Noise abatement takeoffs from Tampa
by CincyDavid
11/24/17 10:30 AM
German & Italian Amazon workers protest Black Fri
by Mr Nice
11/24/17 10:06 AM
colour-blindness-tes
ts
by Oldmoparguy1
11/24/17 09:58 AM
'07 Scion tC looks like burnt intake valves?
by crazy_raccoon
11/24/17 09:47 AM
2015 Dodge Dart 8,073 Valvoline Synpower 0W 20
by Toto
11/24/17 09:40 AM
Understanding TBN in Modern Heavy Duty Engine Oils
by wemay
11/24/17 09:31 AM
new battery
by SteveSRT8
11/24/17 09:07 AM
Thinking of buying...1994 Volvo wagon as a DD
by ryan2022
11/24/17 08:56 AM
Black Friday.... Heaven or [censored]?
by ZZman
11/24/17 08:21 AM
AC not working 2015 Charger compressor not working
by Blue_Goose
11/24/17 07:38 AM
Makeshift fuel hose bracket (Temporary fix)
by dlundblad
11/24/17 07:16 AM
Will PS4 Go Back to $199 Eventually After BF?
by LoneRanger
11/24/17 06:19 AM
Mobil1 Black Friday Sale
by BlueOvalFitter
11/24/17 04:45 AM
deckm00, Cblove91, CarGuy99, bobcat, Skier
63481 Registered Users
69 registered (Astro_Guy, A_Harman, Berny, ATex7239, andyd, bdcardinal, 5 invisible), 2003 Guests and 15 Spiders online.
63481 Members
66 Forums
274253 Topics
Page 2 of 2 < 1 2
#3196363 - 11/24/13 07:52 AM Re: T6 in my BMW?? [Re: Quattro Pete]
StuDawg Offline
Loc: South Carolina
Originally Posted By: StuDawg
I dont think the 0w40 is rated CJ4 for diesel or heavy duty is it?
Correct, it isn't. If CJ4 is a requirement, then yes, M1 0w-40 may not be the best fit. Although, I believe M1 0w-40 has a stronger add pack than T6. T6 add pack had to be reduced to be more friendly to DPF. Not sure if the OP's truck is DPF equipped...
Interestingly enough, in Europe, XOM sells a product called M1 0w-40 Turbo Diesel, and it's the exact same oil as the regular M1 0w-40.
Quote:
Where is 0w40 cheaper than $20-$21 a gallon?
Walmart. M1 0w-40 is $25 for 5qts. T6 is $21.50 for 4qts.
Thanks for that info...my 7.3 is definitely NOT DPF equipped, (pretty sure I wouldnt own a vehicle with that nonsense)....Are you saying I might be better off running the M1 0w40 across the board?
2002 Ford Excursion Limited 4x4 7.3L PSD, Rotella T6 5w-40
2005 Toyota Land Cruiser UZJ100, Mobil 1 5w-30
1988 Toyota Land Cruiser FJ62, Castrol 20w-50
#3196477 - 11/24/13 09:32 AM Re: T6 in my BMW?? [Re: StuDawg]
Garak Online   content
Loc: Regina, Saskatchewan, Canada
You might be able to, assuming M1 0w-40 has the appropriate specification for your 7.3. Up here at least, it's CF rated.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 57356
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3196779 - 11/24/13 04:03 PM Re: T6 in my BMW?? [Re: StuDawg]
Quattro Pete Offline
Loc: Great Lakes
As Garak said, depends on what particular specs your Excursion calls for. What does the manual say?
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#3196946 - 11/24/13 06:54 PM Re: T6 in my BMW?? [Re: StuDawg]
StuDawg Offline
Loc: South Carolina
Looks like its CG-4/SH, as in, both. Manual says it has to meet both, not just one or the other. I think Im just gonna have to stick to T6 and M1 for the bimmers.
#3197148 - 11/24/13 10:08 PM Re: T6 in my BMW?? [Re: StuDawg]
Ducati996 Offline
Loc: Florida Ma.
Iíve pondered that question for a long time.
Iíve also read everything I could find on gasoline and diesel engine oils and Iíve come to this conclusion.
This is my opinion!
Diesel engine oils contain detergents to hold soot in suspension and neutralize acids until the oil can be replaced, detergents weaken the surface tension of the oil which can permit breaching of the fluid film and could allow metal to metal contact during extreme loads & temperatures if used in a gasoline engine.
Diesels engines have much larger bearing surfaces to carry the loads generated and typically turn much slower than gasoline engines (the older large diesels anyways)
Gasoline engines have much smaller bearing and thrust surfaces and also operate at higher speeds. This requires motor oil with very high surface tension (high film strength) to prevent failure of the fluid film separating the components.
I recently replaced the cam & lifters in my Dodge Cummins diesel and found this information.
To ensure a long service life a camshaft break-in additive such as ZDDP is needed and a specific operating procedure is required to ensure proper break-in of the cam/lifter interface during the first 30 minutes.
I also read that gasoline MOTOR oils may be better for this particular task.
Now in all honesty most drivers donít operate their vehicles at or near the threshold of the lubricants ability to maintain separation of bearing surfaces so itís unlikely that you or I would see the shortcomings of using quality diesel oil in a gasoline engine.
But if you have a highly tuned Hi-performance BMW you might want to stick with what BMW recommends.
My 2 cents!
Ducati996
#3203943 - 12/02/13 01:24 PM Re: T6 in my BMW?? [Re: Ducati996]
StuDawg Offline
Loc: South Carolina
Thanks for that Ducati. My bimmers are both stock. I read somewhere that a Shell OEM technical advisor said that Rotella T would be fine for gas engines, the only issue would be the 15w-40 viscosity might be too thick for very cold temps, so then the T6 5w-40 would be preferable.
#3207000 - 12/05/13 08:04 AM Re: T6 in my BMW?? [Re: StuDawg]
ac_tc Offline
Loc: sweden
"Diesels engines have much larger bearing surfaces to carry the loads generated and typically turn much slower than gasoline engines (the older large diesels anyways)"
Well..yes and no, you have to look at surface speed not rpms
to do this comparison, the same hplds true for piston speed.
Their generally larger dimensions increases surface speed so
that they may be equal to a gas engine.
-98 Dodge Durango 5.9 4*4 HDEO 10w- 40 ci4
-04 PT Cruser GT 10w- 40 HDEO ci4
-Everything else HDEO 10w- 40 ci4/STOU 10w-30/THF
#3218820 - 12/16/13 06:03 PM Re: T6 in my BMW?? [Re: StuDawg]
Bandito440 Offline
Loc: NEUS
Of course you can use T6 in all of those vehicles. You could dial in specific oils for each vehicle with UOA and perhaps achieve 1ppm better wear or save a dollar in the process. But to me, the ease of using one oil for all vehicles makes things a lot easier and worth the extra dollar. While you're at it, put it in any outdoor power equipment, ATVs, or motorcycles that don't need something heavier.
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
Page 2 of 2 < 1 2
