I noticed the Focus was groaning when coasting to a stop. Also, when sitting on a hill, it wouldn't roll without the brakes. LF wheel and tire was getting warm.
Pulled the wheel off expecting stuck sliders. Next was a stuck piston.
Nope - the clips. This has happened on EVERY vehicle with disc brakes we got. Usually it's the rear. This time it was the front on the Focus.
Looks like the clips that stop the brake pads from chattering around caused the pads to seize. The inner pad had to be removed with a pry bar and hammer and the outer pad, while somewhat seized was able to be removed with just a pry bar.
The purpose of these clips is to stop the pads from chattering. They serve NO safety purpose.
With that said, I removed them on the drivers and the brake no longer drags and car seems to stop better - pedal modulation is a bit better.
Unfortunately, I'll need to put new rotors on. The inner pad seized some time ago and never made contact with the rotor - so the inside of the rotor is pretty rusted up.
Pulled the right side apart and it is working fine.
This was fun on a 19F, windy day!
