My 2005 Camry SE 4cyl std trans which I bought new runs great @105K miles. Always used
Conventional Mobil or Toyota oil now using Mobil Super HM 5W-30 always has used 1/3-1/2
QT between 4000 mi changes which does not concern me. I need a recommendation for a good
preventative maintenance fuel system cleaner. I always use Shell 87 and once In awhile a tank of V-power which they say has more cleaner. In the past I have used Gumout Regain a couple of times with no obvious results. I just recently took a long road trip had to fill
up a couple of times with non big name fuels so I put in a small bottle of Lucas Upper Cyl Lube with injector cleaner. How does this compare to other brands such as Gumout or Tecron.
I know BG 44 is great stuff but expensive and may be over kill here. I am considering using that new Lucas Deep cleaner once and then Their upper cyl stuff maybe twice a year. Any experince with Lucas products. Also does anyone know who bottles the Toyota Injector cleaner for them? So many opinions on these products It's hard to know which to use.
Thank you Coastalguy
