Your trims at idle are normal enough. Unfortunately that suggests to me that you probably are going to be doing a cat replacement.
The large negative trims don't look too good. I think that's worth investigation. It doesn't make a lot of sense replacing a cat if there's still a running problem. Your PCM is having to take away quite a bit of fuel when you get the engine turning.
Normally, on a Dodge I'd first check the fuel pressure. I expect you won't have a guage on-hand but you can probably borrow one from an auto parts store. If the fuel pressure checks out, make sure the charcoal canister purge solenoid isn't stuck open (if you can blow through it while it's unplugged it's stuck open) or installed upside down. It should be labeled with TOP on the top.
I have no idea what impact the "wrong" (as far as the PCM calibration is concerned) temperature thermostat is going to have on things with this truck. It might be a good idea to ask the other guys with that engine running cold what they get as normal trims. If they're all seeing the -10 to -12 also and not eating cats then you can dismiss it.
