Hi, i have just rebuilt a Honda gx340 engine i got given by a builder which was used as a pressure washer after its rod snapped and caused carnage in the engine, everything was OK cam shaft wasn't bent or damaged, balance shaft wad fine the crank had aluminum melted to it which came off with a bit of 800 grit all i replaced was the rod and pistons and rings i also honed the bore after cleaning it out thoroughly i assembled it set valve lash as per the Honda manual which i have done hundreds of times and then tried to fire it up it was incredibly hard to pull over i had to put one foot on the engine but when i take the spark plug out it spins freely with no resistance the decompressor isn't stuck either as i took the side case off to see if that was the issue. this is my first gx340 i have only worked on gx160's and gx200's before and i would say it is at least five times as hard to pull over as them is this normal?
