Originally Posted By: hattaresguy
The subs I have that run Ford's have nothing but problems with those motors. Plugs blow, they have a lot of valve problems, and they just blow.
The post you just replied to showed the plugs from an early 3V which does NOT blow plugs. It was the older (2002 and older) 2V that launched them. The EARLY 3V engines had a problem with the plugs sticking, the complete opposite of your complaint here...
Quote:
150k is a lot on one it seems.
Weird, we have two of them with a fair bit more than that on them(the old 2V ones with the suicide plugs) and they run as good as new. We've owned 3x 2V 5.4L's and 1x 4.6L and we have ZERO complaints about the engine other than the potential for it to launch plugs (of which only mine has done it and it was only one plug).
They also don't have lots of valve problems. There were a few that got rough timing chain tensioners that needed to be replaced but that wasn't overly common. Some of the 3V engines had a tendency for the VCT phasers to rattle a bit, but it wasn't a reliability problem.
I'm sorry, but our rather extensive (close to 1,000,000Km's between the three Expedition's we've owned) experience with the 5.4L does not in any way resemble your opinion on them.
Quote:
Same as the Powerjoke. OMFG that motor is a POS, every mason dump or flat bed is in the shop all the time and its always over $1k to get it back out. The trick with those seems to be to trade them in as soon as the warranty is up.
The 6.0L and 6.4L were certainly problematic, but the 7.3L that came before it was very reliable as is the new Scorpion diesel.
Quote:
The guys who run GM's and Toyota's don't cry much, Dodge guys cry a bit more, Ford guys...you just feel bad for them after awhile.
All the guys that run GM's go like 200k+++ with one set of plugs, a few oil changes and a couple air filters....
Hmmm, looks like I'm going to have to have a talk with the Expeditions and the work trucks and tell them to start being unreliable piles so that you can feel sorry for me
