It's time to change the transmission fluid in the 2006 Grand Caravan. Actually, at 108,000 miles it's a bit overdue. I'm trying to decide which fluid to use in it. Because of local availability I've narrowed it down to Mopar +4, Castrol Transmax +4, and the BG synthetic universal transmission fluid, there are also a couple +4 store brands but I normally stick with name brands on lubricants. A friend of mine works at a shop where they exclusively use the BG and says they've had really good success with it. It seems to be really good stuff. From what I can find on here the +4 fluids are also very high quality. I've seen a few opinions on here but would like to get a few more and hear what others have used and how things have gone.
A sub-question is would it be better to drop the pan, change filter, and refill, or flush it. I've heard opinions in favor of both. Apparently, Chrysler strongly recommends avoiding flushes. But on the other hand with a dry fill capacity of over 9 quarts dropping the plan will only change less than half of the fluid.
Thoughts?
Thoughts?
