Originally Posted By: cchase
There is a dipstick hole and a fill hole on the V6, but on most peoples cars the fill hole is replaced by a jet that was installed as part of a recall.
I filled through the dipstick.
This was only on the early V-6 transmissions that had the jet kit recall. Our MDX gets filled through the fill plug at the back of the transmission (as pictured above) because it came with the redesigned and upgraded transmission, with no cooling jet kit recalls. It has a very very narrow dipstick tube; I assume I could fill it through that, but it'd take forever. Our CR-V's transmission doesn't have the large fill plug at the top, and it gets filled through a much wider dipstick tube that was clearly designed to be a fill tube as well.
