I have to replace one of the catalytic convertors on my truck. I have the California Emissions system with 2 mini-cats up front and a larger main cat in front of the muffler. Rather than pay a shop $800.00 to replace just the one defective cat I am planning to buy the entire assembly with the 2 mini-cats, pipes and main cat convertor and replace it all and be done with it. I figure if one mini-cat is bad the other is probably not far behind. I can get the assembly from Rock for about $380.00 shipped. I have 2 cats up on either side of the transmission just below the exhaust manifolds.
The cats have short pipes going up to the donut junction from the manifold. Each one has 2 bolts on it, they are rusted and probably seized tight from thousands of heat and cool down cycles. Question is how do you remove the nuts? Is it possible to get the nuts loose without breaking the bolts off? Or should I count on the bolts breaking off and having to drill the bolts out? I am thinking it will be best to spray with Kroil or PB Blaster the night before I start the job. Am I right in assuming the bolts have to be replaced with new ones? Any help here is much appreciated.
