Flaring tool
by P10crew - 02/25/20 01:52 PM
Hazet 600LG/8 Wrench set - $160
by drtyler - 02/25/20 01:34 PM
Cartridge Filter Question
by Tundra73 - 02/25/20 01:21 PM
Buying another car of the same generation
by brages - 02/25/20 01:02 PM
Buying Tires on Amazon
by jcartwright99 - 02/25/20 12:52 PM
plated cylinder liners and sulphur
by alex_at - 02/25/20 12:31 PM
Have we reached the ceiling in improvents to PCMO?
by Speak2Mountain - 02/25/20 11:59 AM
International travel for pleasure
by Pew - 02/25/20 11:42 AM
maxi scooter - should i change the oil now?
by alex_at - 02/25/20 11:05 AM
Toyota NA vs Toyota Global...
by mv6845 - 02/25/20 10:11 AM
How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
BJD2020, ToyTaco2002, EarlT500, Newbie111, Boris_Be
70800 Registered Users
93 registered members (alex_at, 1978elcamino, A_User55555, Astro_Guy, 03s, Bailes1992, 9 invisible), 2,576 guests, and 16 spiders.
Topics301,913
Posts5,205,258
Members70,800
Page 6 of 7 1 5 6 7
Re: Toyota oil filter housing rant [Re: greenjp] #3166382 10/24/13 02:05 PM
G
gman2304 Online Content
Online Content
G
The first oil change on my wifes 06 Toyota Avalon I used a strap wrench...worked like a charm. The problem is the King Kong types get carried away and then you will need the "$pecial wrench".
Re: Toyota oil filter housing rant [Re: greenjp] #3166400 10/24/13 02:14 PM
O
OVERKILL Online Content
Online Content
O
Originally Posted By: greenjp
Also note in that BMW photo that the filter housing has accomodations for both a special cap wrench (or at least it appears that way) as well as a standard socket, albeit a large one. I've used slip-joint channelocks on my Aunt's old 530.
jeff
Yup, IIRC, it is 24mm. I just use a 1/2" ratchet with the necessary socket on it.
Re: Toyota oil filter housing rant [Re: greenjp] #3166408 10/24/13 02:20 PM
M
Mykl Offline
M
If a proprietary, non standard tool is required for the relatively simple task of changing the oil, the manufacturer is doing it wrong.
I would argue the same for transmission fluid.
'10 Volkswagen GTI
'07 Toyota Camry XLE V-6
Re: Toyota oil filter housing rant [Re: supton] #3166424 10/24/13 02:34 PM
U
UG_Passat Online Content
Online Content
U
Originally Posted By: supton
Good question; no idea. On my VW the filter comes out sopping wet, and I wind up vacuuming out the housing. The oil cooler is right under the filter, and there's a good amount that can get pulled from there.
That's because you only experienced the new version of the cartridge filter, where it has an actual necessary orientation, as it had a solid "dam" area in the center support tube. This prevented from having all of the oil draining back into the sump.
THe older version of that filter did not have that dam, so there was no orientation needed.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Toyota oil filter housing rant [Re: hattaresguy] #3166471 10/24/13 03:37 PM
Hootbro Offline
Some of you guys need your "man card" revoked whining about this. Acting like the very minimal extra care to remove skid plates and removing the cartridge filter is going to get your polo shirt and khaki pants dirty.
Jeez, put down your Pumpkin Spiced Latte and get both hands dirty and quit whining it is not like MB or BMW.
2020 Jeep Gladiator Rubicon 3.6L (Dealer Bulk 0W-20)
2017 Jeep Renegade Latitude 2.4L (Idemitsu 0W-20)
2013 Volkswagen Jetta 2.5L (Havoline HM 5W-30)
Re: Toyota oil filter housing rant [Re: Hootbro] #3166476 10/24/13 03:42 PM
O
Online Content
O
Says the guy with three Toyota's wink
Re: Toyota oil filter housing rant [Re: OVERKILL] #3166485 10/24/13 03:47 PM
Hootbro Offline
This guy with three Toyota's and three cartridge filter setups, does his own oil changes and does not whine about it.
Re: Toyota oil filter housing rant [Re: Hootbro] #3166490 10/24/13 03:51 PM
O
Online Content
O
Well I'm the guy with 2x BMW's that take cartridges and 1x Ford 4x4 with a front diff in the way that takes an FL-820S and who ALSO does his own oil changes and doesn't whine about it wink But it doesn't mean I can't critique what other marques have done to make a change on their vehicles a bigger PITA than it needs to be wink
Re: Toyota oil filter housing rant [Re: Hootbro] #3166492 10/24/13 03:54 PM
SatinSilver Offline
wink
Re: Toyota oil filter housing rant [Re: Mykl] #3166515 10/24/13 04:16 PM
Y
y_p_w Online Content
Online Content
Y
I have some doozies.
At least for my 2004 WRX, the manual transmission drain bolt had a T-70 Torx head. Hard time finding it back in 2004 and I ended up spending almost $30 on a fancy German made one. It's now pretty easy to find for less than $10. I remember contacting Lisle to ask if they would consider it, and they said they never heard of an application for a T-70. They have one now. It's used on some other stuff, including the front diff in some Subarus.
And when I worked on bicycles, I built my own wheel with a fancy Campagnolo front hub I bought on eBay. It was beautiful polished aluminum but I wanted to rebuild it. It had these unique dust caps and I ended up scratching them trying to remove them with a common tools. Turns out there was a specialty tool just for this particular part. The hub was only a design for a couple of years. I paid a shop $5 just to take it off without scratching it more.
This was the tool to remove the dust cap:
Re: Toyota oil filter housing rant [Re: Hootbro] #3166546 10/24/13 04:44 PM
H
hattaresguy Offline
H
I appreciate good designs and point out poor ones regardless of who designs them.
Re: Toyota oil filter housing rant [Re: Hootbro] #3166554 10/24/13 04:50 PM
G
greenjp Offline OP
G
Sure tough guy, come and get it LOL
Re: Toyota oil filter housing rant [Re: hattaresguy] #3166759 10/24/13 07:21 PM
A
antiqueshell Offline
A
Absolutely correct, this is the way it SHOULD BE.
Apologists need not apply.
I am a "fan" of VW products..... HOWEVER I am actually MORE critical of their design and engineering compared to other competing brands because HOPEFULLY consumer input does have an influence on the design of future products.
The companies will not respond to input if the consumer doesn't offer it up, and supplying it in a persistent manner as well is actually the best way to approach manufacturers. the squeaky wheel really does get the oil.
Re: Toyota oil filter housing rant [Re: hattaresguy] #3166846 10/24/13 08:42 PM
H
HTSS_TR Offline
H
The splash shield under the Volvo V70 is BIG, hold up by 7-8 bolts. Remove it isn't bad but reinstall is pain in the bud.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
Re: Toyota oil filter housing rant [Re: greenjp] #4976444 01/11/19 06:54 PM
A
anndel Offline
A
I've been doing changes on our 2005 Toyota Avalon since 2005 and that car came with the cartridge-type filter. I use a 3/8 in drive ratchet to remove the cap and the plastic nipple to drain the filter housing. Then I grab the biggest Channellock I have and remove the housing (by the numerous scratches on the aluminum housing). I just bought a Motivx tool a couple year ago along with the drain hose you screw into the housing to drain it. Yeah a bit more work than the can filters and messier but not a show stopper.
1993 Toyota 4x4 p/u, 2.4L 22RE 4 cyl - M1 EP 10W-30, Fram UG Filter
2005 Toyota Avalon XL, 3.5L V6, Amsoil XL 5W-30, Amsoil Filter
2014 Toyota Tacoma 4.0L V6, Amsoil SS 5W-30, Yota OEM Filter
Page 6 of 7 1 5 6 7
