Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
First Time Timesert Install Questions
by The Critic - 03/28/20 01:56 PM
Ontario Nuclear update
by OVERKILL - 03/28/20 01:42 PM
VIDEO: Degreasing cast aluminum engine parts!
by dwcopple - 03/28/20 01:37 PM
Was I charged a fair price for welding exhaust?
by atikovi - 03/28/20 01:24 PM
McKee’s 37
by buster - 03/28/20 01:21 PM
1990 Toyota 4x4 transmission fluid type
by R1jake - 03/28/20 01:08 PM
Another 1911
by Marco620 - 03/28/20 12:23 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
86 registered members (aquariuscsm, 53' Stude, 2K2AcuraTL, 14Accent, Anthony, antonmnster, 8 invisible), 1,521 guests, and 21 spiders.
Topics303,298
Posts5,233,441
Members71,038
Page 7 of 8 1 6 7 8
Re: They Call it "Lucas" Oil Stabilizer [Re: OVERKILL] #3156147 10/15/13 02:26 AM
dixon700 Offline
Originally Posted By: dixon700
I've always heard good things about Lucas.. I'm kind of worried now if I quit using it my seals will really start leaking and I'm kind of worried about my hot idle oil psi. It's only about 25psi now. So the synthetic Lucas gives me nothing that the delvac doesn't?
Good things from whom? Certainly not CAT, Detroit, Cummins, International....etc. The Lucas additives have no factory endorsements or approvals.
What's factory spec for your hot idle? If it is low, you have wear. And that's yet another indication that the Lucas hasn't helped wink
The Lucas makes your oil heavier. But it also dilutes the excellent additive package, viscosity characteristics...etc of the Delvac product. A product that DOES carry numerous OEM approvals (unlike the Lucas). So no, you are not making your oil better, you are making it worse.
I don't know anyone from any of the diesel engine manufacturers. Is there any oem approved additives. I believe I'm still above specs for minimum oil psi. Min 25 at hot idle and 60psi cruising around 2k rpm. My next Oic I guess I'll have to run straight delvac and see how my analysis comes out.
04.5ram CTD lots of parts delvac15w-40 just delvac next time Donaldson elf7349 02 elantra gt castrol edge10w-30 oem filter
Re: They Call it "Lucas" Oil Stabilizer [Re: dixon700] #3156148 10/15/13 02:30 AM
dixon700 Offline
Here is a photo of my past 3 analysis. Took a pic of the PDF and then linked a pic.
Here is just delvac 1300 PHYSICAL TESTS Standard/ranges -a Mobil Delvac 1300 TBN, mg KOH/g, (ASTM D2896) 9.66 Viscosity @ 100C, cSt, (ASTM D445) 14.4 Viscosity @ 40C, cSt, ASTM D445 10829 108 Viscosity Index (ASTM D2270) 136 Viscosity @ -20C mPa s (cP) (ASTM D5293) 6,121 ELEMENTAL ANALYSIS -b Additives Calcium 1,347 Magnesium 911 Phosphorus, ppm 877 Zinc, ppm 1,012 Molybdenum, ppm 48 Barium, ppm <1
Boron, ppm 65 Silicon, ppm-d 6 Potassium, ppm <1 Manganese, ppm <1 Titanium, ppm <1 Copper, ppm <1 Sodium, ppm 4 Vanadium, ppm <1 Contaminants Silver, ppm <1 Aluminum, ppm <1 Chromium, ppm <1 Iron, ppm <1 Nickel, ppm <1 Lead, ppm <1 Antimony, ppm <1 Tin, ppm <1
Re: They Call it "Lucas" Oil Stabilizer [Re: OVERKILL] #3156151 10/15/13 02:50 AM
dixon700 Offline
Should I mention my truck is far from stock? S363 over s475 compound turbos had 75% over injectors and now going to be 100% overs, heavier 110lb valve springs, large stroker cp3, and lots of other odds and ends, but the head has never been off I'm running a stock bottom end. My head is studded though. My truck regularly sees 1600* egts, 65psi boost, and 4000+ rpms. I wasn't sure if the fact that it gets beat like a red headed step child and makes plenty of power to hurt things would effect anything.
What are your oil temperatures? That's going to be the deciding factor as to whether you need a heavier lubricant or not. If they are much higher than stock, stepping it up a grade to a heavier Diesel-spec oil might make sense. But then so would just adding an oil cooler (or a bigger oil cooler) to bring the temps back into the stock range.
I do not measure my oil temperature so I do not know.
Re: They Call it "Lucas" Oil Stabilizer [Re: LTrippett] #3156378 10/15/13 09:52 AM
O
OVERKILL Offline
O
I would install an oil temperature gauge, it is useful on something that is as far from stock as your vehicle (though it is useful on stock vehicles too, just moreso on the non-stock ones).
And I wasn't implying that you knew anybody from the big diesel manufacturers. Simply that NONE of them endorse the use of, nor do they approve the use of additives like Lucas in their engines.
Re: They Call it "Lucas" Oil Stabilizer [Re: LTrippett] #3156596 10/15/13 01:10 PM
dixon700 Offline
Ok I see. I didn't really want to add anymore gauges in my truck since I already have 6 additional to stock... Something I don't understand is everybody is saying that the Lucas dilutes the additives in the delvac oil, but why is my calcium, phosphorus, and zinc higher than plain delvac?
Re: They Call it "Lucas" Oil Stabilizer [Re: LTrippett] #3156614 10/15/13 01:24 PM
O
OVERKILL Offline
O
Aren't you also adding Motorkote?
Re: They Call it "Lucas" Oil Stabilizer [Re: LTrippett] #3156642 10/15/13 02:02 PM
dixon700 Offline
Yes, but I seen a voa for that in another thread and there was nothin in it. One thing was 4ppm. It sure seems that I'll be sticking to just delvac 1300 and possibly run less than my typical 8k interval. Like 6-6500mi
Re: They Call it "Lucas" Oil Stabilizer [Re: LTrippett] #3157690 10/16/13 12:53 PM
dixon700 Offline
According to a Blackstone voa motorkote looks like a light 20wt oil with a little detergent. All zeros except for 4ppm of boron.
Re: They Call it "Lucas" Oil Stabilizer [Re: dixon700] #3157694 10/16/13 12:57 PM
O
OVERKILL Offline
O
Have you done a VOA for the oil you are currently running?
Re: They Call it "Lucas" Oil Stabilizer [Re: LTrippett] #3157712 10/16/13 01:14 PM
dixon700 Offline
No because I'm not sure how I would give the correct ratio for a voa. My truck takes about 12.5qts and I put 1/2gal Lucas synthetic oil stabilizer and the past 2 oil changes I've added the 12oz of motorkote. I'm currently running the same amounts and when I get my Oci up near the 8k again I will be sending in another sample and possibly cutting back on the Oci if wear metals are that high again. Should I mention most of my oil is from a large bulk tank of delvac from work? Also some times the make up oil may not be delvac, it could of been delo 400 or rotella t. There has been Lucas jugs refilled with new oil and the drivers don't take it, and I'm not going to throw out $13 of oil.
Re: They Call it "Lucas" Oil Stabilizer [Re: LTrippett] #3157741 10/16/13 01:42 PM
O
OVERKILL Offline
O
Well, might want to send off a virgin sample of whats going into your engine the next time (minus the additives) so that you have something to compare it to.
Re: They Call it "Lucas" Oil Stabilizer [Re: LTrippett] #3158359 10/17/13 01:44 AM
dixon700 Offline
Wouldn't it be the same as the voas for delvac 1300 or are you thinking it might be a little different due to being in a storage tank and possible contamination? I'll pour a little from all 3 jugs that will be used next time and send it in for a voa. Should I pay the extra and get the tbn also?
Re: They Call it "Lucas" Oil Stabilizer [Re: MileHigh18] #3158557 10/17/13 09:14 AM
M
Miller88 Offline
M
Originally Posted By: MileHigh18
Originally Posted By: spasm3
I won't let a bottle of lucas anything within 10 feet of my engines.
Agreed. This stuff is junk. Someone gave me a big bottle of LUCL, and I haven't noticed any improvement from using that either. Lucas is all hype.
UCL bottles make great funnels. We got a bunch of them free from somewhere and that's the perfect use for them!
If i lose a funnel, I just cut open a new bottle and dump it in the waste oil bin.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: They Call it "Lucas" Oil Stabilizer [Re: dixon700] #3158817 10/17/13 12:56 PM
O
OVERKILL Offline
O
May not be, considering you say you get it in bulk. And the formulas DO change.
EXACTLY smile
Don't need TBN I don't think on the VOA unless you want to spend the extra money smile
Re: They Call it "Lucas" Oil Stabilizer [Re: LTrippett] #3159463 10/17/13 10:49 PM
dixon700 Offline
Ok I'll pick out 3 jugs that I know are from the bulk and pour a bit of all 3 in there. Send them out for a voa, then run all 3 of those jugs next oil change.
Page 7 of 8 1 6 7 8
