Grease for Poly Bushings?
Tampa, Fl
I installed Polyurethane Bushings in my control arms, and drilled and tapped them with zerks fittings. I have been using plain old chassis grease. Is there something more correct that I should use?
Thanks
-Rouphis
I like a calcium sulfonate thickened (marine) grease as it resists water washout better than most chassis greases which are usually Li or Li complex.
I just used the red M1 grease in mine on the Lincoln......
Is the polyurethane compatible with the lithium complex thickener??
Originally Posted By: UG_Passat
Prothane Super Grease. (since Prothane makes poly bushings....)
You can buy it in cartridge form for your grease gun
http://www.amazon.com/Prothane-19-1751-S...ne+super+grease
This, and some use the Super Lube synthetic clear stuff as well (it's actually recommended by UMI (performance suspension component company) for use in it's Roto-Joint control arm/panhard/a arm/etc. ends with poly or delrin bushings.
But, the Prothane/Energy Suspensions products are MUCH thicker/tackier, and WILL outlast the Super Lube like 10 to 1.
