Originally Posted By: SHOZ
Originally Posted By: TFB1
I remove the cooler line into the radiator, add a length of hose routed into a five gal bucket and start engine, fluid will flow into the bucket... When flow reduces, I start dumping in a total of two quarts less than a dry fill(varies by trans of course)and let all that pump into the bucket... Be sure to have your bottles open, ready to go when adding the fluid that will be added, as it will be pumped into the torque converter replacing old fluid that flows into bucket... When flow reduces, cut engine, reconnect line, restart and top off... Done... No I haven't dropped a pan in years, unless you suspect a issue it isn't necessary...
I like this. Did you get this from TCCA? It is what use to do with my tauruses.
How many quarts does the Malibu take? It looks like you can fill it from the vent tube?
The GM guys have used this trick for years, learned the method when I pulled a hitch with the general back in the '80s...
No idea how much fluid any GM trans requires these days...
