2000 Buick LeSabre
Check engine light is off and no codes stored. About twice a year I'll get the P0451 code which is the fuel tank pressure sensor circuit. I read somewhere that the culprit is an overly sensitive PCM and the only fix is to re-flash it. So I'm not too worried about it. I just erase the code whenever it comes up, which is very seldom.
The engine doesn't idle real real smooth like it used to. It used to be imperceivable as to whether it was running or not. It used to be the only way to you could tell if it was running is to look at the tachometer.
So. . . . . .you guys have any ideas as to why it wouldn't idle as smooth as it used to?
