Any of the premium off-the shelf filters. Look for one that fits and seals the best. Since that aspect is often very application-specific, you will probably have to look at several to see which one fits & seals the best. There is very little to choose between the premium off-the-shelf pieces as far a the media goes... though that is not going to be 100 percent true in all cases. I suggest opening some boxes, looking at the sealing method and the amount and type of media.
I third, or fourth, the "no-blow" advice. Quick way to ruin a filter. You can get away with that on some industrial/ag filters but many PC/LT filters are not robust enough. You can damage the fibers and decrease efficiency and the damage may not be visible. Plus, as stated above, the filter gets more efficient as it loads up. The generic stat is that an air filter will pass half of the lifetime amount of dirt in the first 10 percent of use as it loads up and gets 2-3% more efficient. If you wonder how much that might be... the average filter is around 93% efficient on fine dust. a premium fitelr is iin the 97-98% range and can get into 99% after loading.
Code:
For Every 10 Pounds of Dust Drawn Into the Air Filter Inlet:
EFFICIENCY OF FILTER DUST INTO ENGINE
99.95% 0.005 lbs.
99% 0.10 lbs.
95% 0.50 lbs.
90% 1.0 lbs.
The best way to know when the optimal point to change the filter is via a restriction gauge (google Filterminder). You can't tell much by looking oftentimes.
