Originally Posted By: KCJeep
Put the injector cleaner in right before you are ready to change the oil, a tank or two out.
I like MMO for a bunch of reasons but I don't know why you'd want to add it you just went thicker because you wanted higher pressure MMO will thin your oil back down to a 30 grade most likely.
I decided to put in 3oz of cleaner, not the whole bottle. (Redline SI-1)
As to the MMO.. I have room on my dipstick for about half a quart, or 16oz. so I am not too worried about thinning it. In fact, if my spark plugs or something in engine is cleaning.fouling as I somewhat suspect given the wires and i will know at plugs themselves, I will purchase the MMO then the plugs, then change out the ones I can. better than changing none!
It will be interesting to see if I can maintain oil pressure with MMO in there. I would be at "thin 30" if I didnt have two bars blinking out of a three-bar-blink warning light zone on my gauge. (Wow, mouthful, but exactly accurate.)
Last night's acting up on the way home could have been just a bad and loose ground (and I hope it was that) but now I am so on guard for recurrence that I need to think of
everything I can.
Going to AZ to get my 6 plugs and cheap set of wires (all I can afford.. beats the pic of the spark plug wire you see..)
