Sludge and Facebook's infinite wisdom
by RDY4WAR. 03/24/19 02:05 PM
Gear lube 75W90 Synthetic GM# 88900401
by rcbob. 03/24/19 01:47 PM
Rislone Rebates
by Nickdfresh. 03/24/19 01:42 PM
IndyCar Classic at COTA
by bdcardinal. 03/24/19 12:29 PM
STP 500 at Martinsville
by bdcardinal. 03/24/19 12:27 PM
Source For Microfiber Towels
by Wrenchturner44. 03/24/19 12:26 PM
SUPREME C3-X SYNTHETIC 5W-30
by 21Rouge. 03/24/19 12:17 PM
Do you use your Pick Up like a truck or car?
by ZZman. 03/24/19 10:52 AM
My mom needs a new phone. Ideas?
by kpatter. 03/24/19 09:40 AM
2017 vw Jetta se vs 2017 Ford fusion se
by A1O. 03/24/19 09:39 AM
Fram Pro Synthetic #9688 **NEW** CUT OPEN
by 53' Stude. 03/24/19 08:26 AM
Wagner OEX vs Akebono ProACT
by Patrick0525. 03/24/19 08:12 AM
Plasti Diping my OEM rims question
by dblshock. 03/24/19 07:53 AM
"The new" Mobil 1 Racing Oil ?
by lawnguy. 03/24/19 06:32 AM
Arlen Ness passes
by 02SE. 03/24/19 03:15 AM
Plants - they learn and remember
by Shannow. 03/24/19 03:02 AM
Rotella Gas Truck
by jpstiles02. 03/24/19 02:53 AM
GSXRBullwinkie, Mark1970, FixItDad28, RandomJoe, Sciascia
67599 Registered Users
96 registered members (53' Stude, A1O, 97prizm, 14Accent, Astro14, 10 invisible), 2,439 guests, and 54 spiders.
Topics286,340
Posts4,906,729
Members67,599
Most Online2,967
Mar 10th, 2019
Page 8 of 10 1 7 8 9 10
Re: Archoil products [Re: kimandsally] #3527078
11/01/14 03:23 PM
11/01/14 03:23 PM
Norway
jonny-b Offline
jonny-b  Offline
Norway
However, for his defence, I guess that he has never owned a vehicle with a worn out engine/transmission.
That should be one of the first lessions, if one wants to learn somethings about what is working, or not.
Again, sitting behind a desk, calculating what is possible or not, will never be accurate.
However, paper-tigers will always be telling the opposite.
And of course, since they sit behind a desk all day, they are very clever with words.
It doesn't make their ideas more correct, anyway.
Re: Archoil products [Re: kimandsally] #3527120
11/01/14 04:18 PM
11/01/14 04:18 PM
Mizzou-land
GMorg Offline
GMorg  Offline
Mizzou-land
I'm still not convinced that ground minerals are useful in a fully formulated oil. However, under certain conditions, they can be useful in a virgin, Group I oil.
I snooped around in the literature a little more. It seems that most, if not all, of the papers are from Chinese labs. In my field, that means that a little extra scrutiny is warranted.
If ground minerals are so great, why aren't benefits being described from labs around the world? This stuff may be great, but the jury is still out for me.
Re: Archoil products [Re: kimandsally] #3527196
11/01/14 06:11 PM
11/01/14 06:11 PM
moutain country
boxcartommie22 Offline
moutain country
gmorg, what do you think about archoil's ar9100? a nanoborate
2001 Lincoln Conti,RL,K&N,Hotshots,Lubegard,Archoil
2007 Grand Marquis,RL,K&N,Hotshots,Lubegard,Archoil
2010 Raptor,RL,Hotshots,Lubegard,Archoil
Re: Archoil products [Re: kimandsally] #3527267
11/01/14 07:41 PM
11/01/14 07:41 PM
Mizzou-land
GMorg Offline
GMorg  Offline
Mizzou-land
I think that most of AR9100 text reads like marketing jibberish. It seems like they are trying to use language to imply that they are using borate esters, which can have a place in an oil formulation. However they seem to be using potassium borate (borax, the grit found in some cleaning preparations) suspended in an ester.
Perhaps the ester or the "nanoborate" can have a place in an oil formulation. However, I think that is would be a mistake to assume that you can add any of the Archoil products and improve an otherwise good oil.
Anyone that uses these products and finds them useful should make their own decisions. I am not yet convinced that any of the solids, however small, are miracle additives.
I am convinced that exhaust gases are the major source of heat in a head and that an oil additive is not going to reduce combustion temperatures.
Re: Archoil products [Re: kimandsally] #3527333
11/01/14 09:09 PM
11/01/14 09:09 PM
moutain country
moutain country
thank you gmorg
Re: Archoil products [Re: GMorg] #3799419
07/23/15 04:08 PM
07/23/15 04:08 PM
Murray KY USA
GaleHawkins Offline
GaleHawkins  Offline
Murray KY USA
GMorg I agree about exhaust gases being a major source of heat in a head but I do not follow your logic in the rest of the quote above.
Is your engine consuming a lot of motor oil pass the rings?
Where do you get the idea that AR9100 claims to reduce combustion temperatures?
Re: Archoil products [Re: kimandsally] #3799572
07/23/15 08:00 PM
07/23/15 08:00 PM
Ontario,Canada
DrAdmin Offline
DrAdmin  Offline
Ontario,Canada
Serpentine working as extra-ultra fine abrasive, simply polish a surface, the result more smooth surface shifting curve for lower fric. coeff.
1 worn untreated surface
2 worn treated surface
3 different technique in common to move from rough to smooth surface and therefore shifting curve:
abrasion - serpentine, e.t.c.
metal plating -
polimers or layered compounds - mos2, etc
mechanical loss (vertical in H.m) vs rotation speed in engine over 110K kilometers old; black - untreated; red - treated by LM MOS2:
Again a major effect appears for a worn engine. When engine working at low rotation, below 2000 rpm. Above 2000 usually we see a hydrodynamic lubrication. Therefore the most efficient rpm range is, when additives most efficiency work and do the job, below 2000.
Conclusively, a person with city stop/go traffic will have the most from an additive where highway user a least.
Re: Archoil products [Re: kimandsally] #3799774
07/24/15 03:45 AM
07/24/15 03:45 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Hmmmm, asbestos enriched oils...
Re: Archoil products [Re: kimandsally] #3801539
07/25/15 11:12 PM
07/25/15 11:12 PM
Ontario,Canada
DrAdmin Offline
DrAdmin  Offline
Ontario,Canada
A dark side.
in overall how exactly the mineral react with metal is unknown,
some hypotheses i wouldn't tell .. Due to multiple factors in overall the reaction produce a controversial result. ( can be positive or negative)
finally: unpredicted result, unknown of process, and impossible to control due to multiple variation completely abandon of usage this material as additive.
Re: Archoil products [Re: kimandsally] #3861732
09/22/15 12:52 PM
09/22/15 12:52 PM
Ontario,Canada
DrAdmin Offline
DrAdmin  Offline
Ontario,Canada
I did mention about archoil 9300 a few post earlier, As I said product do 2 things: polished a surface, so it has an abrasion effect, and involve a chemical reaction to create a film in the area of boundary lubrication ( when 2 nano mountains shred each other and produced energy trigger a reaction)
In attempt to order it ... oops , the product do not distributed over regular consumer channels, only auto Technicians etc able to get it.
( does anyone knows Auto Technician, in my area, who can observe cylinder wall by bore-scope, and professionally conclude engine status ?)
Re: Archoil products [Re: jonny-b] #3861820
09/22/15 02:30 PM
09/22/15 02:30 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
Originally Posted By: jonny-b
Thanks a lot GMorg. Several people here, have been tring to explain this, to Molakule, over a period of 3-5 years.
I guess he should now take an extra look at it.
Please feel free to elaborate and clarify.
What specific OTC additive are you referring to?
With regard to Potassium borate esters, they are commonly used as secondary EP additives in gear lubes and function as low-temp EP additives.
Some borate ester are used as AW addiitves in MO's as well.
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: Archoil products [Re: kimandsally] #3862238
09/22/15 09:10 PM
09/22/15 09:10 PM
Ontario,Canada
DrAdmin Offline
DrAdmin  Offline
Ontario,Canada
valve lifer surface:
before treatment:
after treatment:
Re: Archoil products [Re: DrAdmin] #3866699
09/27/15 09:19 AM
09/27/15 09:19 AM
North Carolina
carl2591 Offline
carl2591  Offline
North Carolina
great thread.. I have been seeing the Archoil product being touted by Bill Hewitt at powerstrokehelp.com site.. he mentions and shows both oil and fuel additive as being a great help for diesel engines especially the 6.0L ford engines that develop issues with oil and the injectors.
I know of a few folks with the 6.0L engines that after using just the additives noticed a nice difference in starting, running and with time better MPG.
DR ADMIN,, the info you presented above showing before and after treatment, are you referring to archoil treatment in the oil only or both oil and fuel..
thanks
I have the 7.3L with 170K and plan to add the products when i do oil change later this year.
One question.. with a oil bypass filter, FS2500, will that strip the additive out of the oil over time?? the filter are rated for 3 microns.
Re: Archoil products [Re: DrAdmin] #3866707
09/27/15 09:26 AM
09/27/15 09:26 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
I don't really understand those pictures, is that a good thing and why? Can anyone explain what it shows and why it makes a difference? It appears to show the surface is smoother, but does that help "something" at those relative levels?
And is that an Archoil product or something else? It doesn't say and people are discussing different products in this thread.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Archoil products [Re: kimandsally] #3866726
09/27/15 09:44 AM
09/27/15 09:44 AM
down in the park
Jetronic Offline
Jetronic  Offline
down in the park
smoother surfaces increase the area bearing the load, so less force per unit of area.
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus Prime 2 215/50R17 (front)
Pirelli P7 Cinturato 225/45R17 (rear)
